Datasheet ADG801, ADG802 (Analog Devices)
Description<0.4 Ω CMOS 1.8 V to 5.5 V SPST Switches
Pages / Page16 / 1 — <0.4 Ω CMOS 1.8 V to 5.5 V. SPST Switches. Data Sheet. ADG801/. …
File Format / SizePDF / 299 Kb
<0.4 Ω CMOS 1.8 V to 5.5 V. SPST Switches. Data Sheet. ADG801/. ADG802. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADG801, ADG802 Analog Devices
<0.4 Ω CMOS 1.8 V to 5.5 V SPST Switches Data Sheet ADG801/ ADG802 FEATURES FUNCTIONAL BLOCK DIAGRAM 0.4 Ω maximum on resistance at 125°C ADG801 0.08 Ω maximum on resistance flatness at 125°C S D 1.8 V to 5.5 V single supply Automotive temperature range from −40°C to +125°C 400 mA current-carrying capability IN Tiny 6-lead SOT-23 and 8-lead MSOP packages 35 ns switching times Low power consumption ADG802 TTL-/CMOS-compatible inputs S D Pin compatible with ADG701 /ADG702 IN APPLICATIONS
1
Power routing
00
SWITCHES SHOWN FOR
0-
A LOGIC 1 INPUT
80
Cellular phones
02 Figure 1.
Modems PCMCIA cards Hard drives Data acquisition systems Communications systems Relay replacement Battery-powered systems GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG801 and ADG802 are monolithic CMOS, single-pole, 1. Low on resistance (0.25 Ω typical). single throw (SPST) switches with on resistance of less than 0.4 Ω. 2. 1.8 V to 5.5 V single-supply operation. These switches are designed using an advanced submicron process 3. Tiny 6-lead SOT-23 and 8-lead MSOP packages. that provides extremely low on resistance, high switching speed, 4. 400 mA current-carrying capability. and low leakage currents. 5. Automotive temperature range from −40°C to +125°C. The low on resistance of <0.4 Ω makes these parts ideal for 6. Pin compatible with ADG701 (ADG801) and ADG702 applications where low on resistance switching is critical. (ADG802). The ADG801 switch is normally open (NO), while the ADG802 is normally closed (NC). Each switch conducts equally well in both directions when on.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2002–2012 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
