Datasheet LM158, LM158A, LM258, LM258A, LM358, LM358A, LM2904, LM2904V (Texas Instruments) - 9
Description | Dual Operational Amplifiers |
Pages / Page | 43 / 9 — LM158,. LM158A, LM258. , LM258A. LM358,. LM358A,. LM2904. , LM2904V. … |
Revision | U |
File Format / Size | PDF / 2.0 Mb |
LM158,. LM158A, LM258. , LM258A. LM358,. LM358A,. LM2904. , LM2904V. www.ti.com. 6.10 Typical Characteristics
LM158, LM158A, LM258 , LM258A LM358, LM358A, LM2904 , LM2904V www.ti.com
SLOS068U – JUNE 1976 – REVISED JANUARY 2017
20 0.36 18 0.34 –55C 16 0C 0.32 14 125C dc) 0.3 (nA 12 ent 10 0.28 Current (mA) Curr 8 0.26 put 6 5Vdc In Supply 15Vdc 0.24 4 30Vdc 2 0.22 0 0.2 –55 –35 –15 5 25 45 65 85 105 125 0 5 10 15 20 25 30 Temperature (°C) Supply Voltage (Vdc)
Figure 1. Input Current vs. Temperature Figure 2. Supply Current vs. Supply Voltage
160 100 CMRR 140 RL=20K 90 RL=2K 80 120 (dB) 70 100 ) B 60 Gain (d ge 80 50 lta RR o V 40 60 CM vol 30 A 40 20 20 10 0 0 0 5 10 15 20 25 30 35 40 0.1 1 10 100 1000 V+ Supply Voltage (Vdc) Frequency (kHz) C001
Figure 3. Voltage Gain vs. Supply Voltage Figure 4. Common-mode Rejection Ratio vs. Frequency
3.5 0.50 VOUT 3.0 0.45 2.5 0.40 ) (V 2.0 (V e e g g 0.35 lta 1.5 lta o o V V 0.30 1.0 0.25 0.5 VOUT 0.0 0.20 0 4 8 12 16 20 24 28 32 36 40 0 2 4 6 8 10 Time ( s) Time ( s) C001 C001
Figure 5. Voltage Follower Large Signal Response (50 pF) Figure 6. Voltage Follower Small Signal Response (50 pF)
Copyright © 1976–2017, Texas Instruments Incorporated Submit Documentation Feedback 9 Product Folder Links: LM158 LM258 LM258A LM358 LM358A LM2904 LM2904V Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for LMx58 6.6 Electrical Characteristics for LM2904 6.7 Electrical Characteristics for LM158A and LM258A 6.8 Electrical Characteristics for LM358A 6.9 Operating Conditions 6.10 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Unity-Gain Bandwidth 8.3.2 Slew Rate 8.3.3 Input Common Mode Range 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Examples 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Receiving Notification of Documentation Updates 12.4 Community Resources 12.5 Trademarks 12.6 Electrostatic Discharge Caution 12.7 Glossary 13 Mechanical, Packaging, and Orderable Information
