Datasheet LM158, LM158A, LM258, LM258A, LM358, LM358A, LM2904, LM2904V (Texas Instruments) - 8
Description | Dual Operational Amplifiers |
Pages / Page | 43 / 8 — LM158,. LM158A, LM258. , LM258A. LM358,. LM358A. , LM2904,. LM2904V. … |
Revision | U |
File Format / Size | PDF / 2.0 Mb |
LM158,. LM158A, LM258. , LM258A. LM358,. LM358A. , LM2904,. LM2904V. www.ti.com. Electrical Characteristics for LM358A (continued)
link to page 11 link to page 11 link to page 11
LM158, LM158A, LM258 , LM258A LM358, LM358A , LM2904, LM2904V
SLOS068U – JUNE 1976 – REVISED JANUARY 2017
www.ti.com Electrical Characteristics for LM358A (continued)
at specified free-air temperature, VCC = 5 V (unless otherwise noted)
LM358A PARAMETER TEST CONDITIONS(1) T (2) A UNIT MIN TYP(3) MAX
Average temperature coefficient αVIO Full range 7 20 µA/°C of input offset voltage 25°C 2 30 IIO Input offset current VO = 1.4 V nA Full range 75 Average temperature coefficient αIIO Full range 10 300 pA/°C of input offset current 25°C –15 –100 IIB Input bias current VO = 1.4 V nA Full range –200 0 to 25°C Common-mode input VCC – 1.5 VICR V V voltage range CC = 30 V 0 to Full range VCC – 2 RL ≥ 2 kΩ 25°C VCC – 1.5 VOH High-level output voltage R V L= 2kΩ Full range 26 VCC = 30 V RL≥ 10kΩ Full range 27 28 VOL Low-level output voltage RL ≤ 10 kΩ Full range 5 20 mV Large-signal differential V 25°C 25 100 A CC = 15 V, VO = 1 V to 11 V, VD V/mV voltage amplification RL ≥ 2 kΩ Full range 15 CMRR Common-mode rejection ratio 25°C 65 80 dB Supply-voltage rejection ratio kSVR 25°C 65 100 dB (ΔVDD /ΔVIO) VO1/ VO2 Crosstalk attenuation f = 1 kHz to 20 kHz 25°C 120 dB VCC = 15 V, 25°C –20 –30 −60 VID = 1 V, Source V Full range –10 O = 0 mA IO Output current VCC = 15 V, 25°C 10 20 VID = –1 V, Sink V Full range 5 O = 15 V VID = –1 V, VO = 200 mV 25°C 30 μA V I CC at 5 V, GND at –5 V, OS Short-circuit output current 25°C ±40 ±60 mA VO = 0 VO = 2.5 V, No load Full range 0.7 1.2 Supply current ICC mA (four amplifiers) VCC = MAX V, VO = 0.5 V, Full range 1 2 No load
6.9 Operating Conditions
VCC = ±15 V, TA = 25°C
PARAMETER TEST CONDITIONS TYP UNIT
SR Slew rate at unity gain RL = 1 MΩ, CL = 30 pF, VI = ±10 V (see Figure 11) 0.3 V/μs B1 Unity-gain bandwidth RL = 1 MΩ, CL = 20 pF (see Figure 11) 0.7 MHz Vn Equivalent input noise voltage RS = 100 Ω, VI = 0 V, f = 1 kHz (see Figure 12) 40 nV/√Hz 8 Submit Documentation Feedback Copyright © 1976–2017, Texas Instruments Incorporated Product Folder Links: LM158 LM258 LM258A LM358 LM358A LM2904 LM2904V Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for LMx58 6.6 Electrical Characteristics for LM2904 6.7 Electrical Characteristics for LM158A and LM258A 6.8 Electrical Characteristics for LM358A 6.9 Operating Conditions 6.10 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Unity-Gain Bandwidth 8.3.2 Slew Rate 8.3.3 Input Common Mode Range 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Examples 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Receiving Notification of Documentation Updates 12.4 Community Resources 12.5 Trademarks 12.6 Electrostatic Discharge Caution 12.7 Glossary 13 Mechanical, Packaging, and Orderable Information
