Datasheet LM158, LM158A, LM258, LM258A, LM358, LM358A, LM2904, LM2904V (Texas Instruments) - 7
Description | Dual Operational Amplifiers |
Pages / Page | 43 / 7 — LM158,. LM158A, LM258. , LM258A. LM358,. LM358A,. LM2904. , LM2904V. … |
Revision | U |
File Format / Size | PDF / 2.0 Mb |
LM158,. LM158A, LM258. , LM258A. LM358,. LM358A,. LM2904. , LM2904V. www.ti.com. 6.7 Electrical Characteristics for LM158A and LM258A
LM158, LM158A, LM258 , LM258A LM358, LM358A, LM2904 , LM2904V www.ti.com
SLOS068U – JUNE 1976 – REVISED JANUARY 2017
at specified free-air temperature, VCC = 5 V (unless otherwise noted)
LM158A LM258A PARAMETER TEST CONDITIONS(1) T (1) A UNIT MIN TYP(2) MAX MIN TYP(2) MAX
VCC = 5 V to 30 V, 25°C 2 2 3 VIO Input offset voltage VIC = VICR(min), mV V Full range 4 4 O = 1.4 V Average temperature αVIO coefficient of input Full range 7 15(3) 7 15 µA/°C offset voltage 25°C 2 10 2 15 IIO Input offset current VO = 1.4 V nA Full range 30 30 Average temperature αIIO coefficient of input Full range 10 200 10 200 pA/°C offset current 25°C –15 –50 –15 –80 IIB Input bias current VO = 1.4 V nA Full range –100 –100 0 to 0 to 25°C Common-mode input VCC – 1.5 VCC – 1.5 VICR V V voltage range CC = 30 V 0 to 0 to Full range VCC – 2 VCC – 2 RL ≥ 2 kΩ 25°C VCC – 1.5 VCC – 1.5 High-level output VOH R V voltage L= 2kΩ Full range 26 26 VCC = 30 V RL≥ 10kΩ Full range 27 28 27 28 Low-level output VOL R voltage L ≤ 10 kΩ Full range 5 20 5 20 mV Large-signal 25°C 50 100 50 100 V A CC = 15 V, VO = 1 V to 11 V, VD differential voltage V/mV R amplification L ≥ 2 kΩ Full range 25 25 Common-mode CMRR 25°C 70 80 70 80 dB rejection ratio Supply-voltage k rejection ratio SVR 25°C 65 100 65 100 dB (ΔVD /ΔVIO) Crosstalk VO1/ VO2 f = 1 kHz to 20 kHz 25°C 120 120 dB attenuation VCC = 15 V, 25°C –20 –30 –60 –20 –30 −60 VID = 1 V, Source V Full range –10 –10 O = 0 mA IO Output current VCC = 15 V, 25°C 10 20 10 20 VID = –1 V, Sink V Full range 5 5 O = 15 V VID = −1 V, VO = 200 mV 25°C 12 30 12 30 μA Short-circuit V I CC at 5 V, GND at –5 V, OS 25°C ±40 ±60 ±40 ±60 mA output current VO = 0 VO = 2.5 V, No load Full range 0.7 1.2 0.7 1.2 Supply current ICC mA (four amplifiers) VCC = MAX V, VO = 0.5 V, Full range 1 2 1 2 No load (1) All characteristics are measured under open-loop conditions, with zero common-mode input voltage, unless otherwise specified. MAX VCC for testing purposes is 26 V for LM2904 and 30 V for others. (2) All typical values are at TA = 25°C. (3) On products compliant to MIL-PRF-38535, this parameter is not production tested.
6.8 Electrical Characteristics for LM358A
LM358A PARAMETER TEST CONDITIONS(1) T (2) A UNIT MIN TYP(3) MAX
VCC = 5 V to 30 V, 25°C 2 3 VIO Input offset voltage VIC = VICR(min), mV V Full range 5 O = 1.4 V (1) All characteristics are measured under open-loop conditions, with zero common-mode input voltage, unless otherwise specified. MAX VCC for testing purposes is 26 V for LM2904 and 30 V for others. (2) All characteristics are measured under open-loop conditions, with zero common-mode input voltage, unless otherwise specified. MAX VCC for testing purposes is 26 V for LM2904 and 30 V for others. (3) All typical values are at TA = 25°C. Copyright © 1976–2017, Texas Instruments Incorporated Submit Documentation Feedback 7 Product Folder Links: LM158 LM258 LM258A LM358 LM358A LM2904 LM2904V Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for LMx58 6.6 Electrical Characteristics for LM2904 6.7 Electrical Characteristics for LM158A and LM258A 6.8 Electrical Characteristics for LM358A 6.9 Operating Conditions 6.10 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Unity-Gain Bandwidth 8.3.2 Slew Rate 8.3.3 Input Common Mode Range 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Examples 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Receiving Notification of Documentation Updates 12.4 Community Resources 12.5 Trademarks 12.6 Electrostatic Discharge Caution 12.7 Glossary 13 Mechanical, Packaging, and Orderable Information
