Articles and news - Microcontrollers - 5
8-bit PWM 8-bit Dpot 16-bit hybrid
8-bit PWM + 8-bit Dpot = 16-bit hybrid DAC
Aug 29, 2024 Circuits
Pulse width modulation is a terrific basis for digital to analog conversion. Credit goes to features like simplicity and perfect differential and integral linearity. Unfortunately, PWM’s need for ripple filtering tends to make it slow...
Microcontroller supervises 0- 20-mA protection circuit
Microcontroller supervises 0- to 20-mA protection circuit
The 0- to 20-mA current loop is a reliable means of data communication in industrial applications. These circuits use a precision shunt in the receiver to convert the current signal into a voltage signal...
One microcontroller pin drives two LEDs
One microcontroller pin drives two LEDs with low quiescent current
Jun 11, 2024 Circuits
The basis for this Design Idea is a circuit that uses three resistors and a microcontroller-I/O pin to work as input high impedance or output to independently drive two LEDs...
Zilog calls time on venerable Z80
Zilog calls time on the venerable Z80, discontinues the standalone Z84C00 CPU family
May 23, 2024 News
While the long-lived Z80 continues on in Z180 and eZ80 forms, the standalone DIP-packaged variants' days are numbered...
Non-linear pullup multi-rate sup sup buses
Non-linear pullup for multi-rate I2C buses
May 13, 2024 Circuits
I2C is a popular bidirectional serial communications bus having a clock and a data line. Both line’s drivers consist of an open drain ground-referenced N-channel MOSFET with a pullup resistor connected to a supply...
Programmable Schmitt triggers are digitally controlled
May 10, 2024 Circuits
The circuit is a single-supply version of a programmable Schmitt trigger, or a comparator with hysteresis...
Seeed unveils compact matter-ready XIAO ESP32C6
Seeed unveils the compact matter-ready XIAO ESP32C6 dev board
Apr 9, 2024 News
Seeed Studio has launched a new entry in the XIAO family of small form factor microcontroller development boards, built around the Espressif ESP32-C6: the RISC-V XIAO ESP32C6, boasting Wi-Fi 6, Bluetooth 5.3 Low Energy (BLE), and Matter-ready IEEE 802.15.4 connectivity...
STMicroelectronics high-performance microcontrollers pave way new
STMicroelectronics' high-performance microcontrollers pave the way to new innovations in smart home and industrial systems
Apr 5, 2024 News
New STM32H7R/S microcontrollers raise embedded-application performance to new levels for next-generation smart devices in factories, buildings, infrastructure, eHealth...
What Is Machine Learning Part Hardware
What Is Machine Learning? Part 3 - Hardware Conversion of Convolutional Neural Networks
Mar 1, 2024 Articles
Part 3 will explain the hardware conversion of a CNN and specifically the benefits of using an artificial intelligence microcontroller with a hardware-based CNN accelerator...
What is machine learning Part Training
What is machine learning? Part 2 - Training convolutional neural networks
Feb 29, 2024 Articles
This is part 2 in a series of articles focusing on the properties and applications of convolutional neural networks, which are mainly used for pattern recognition and the classification of objects...
