Articles and news - Microcontrollers - 6
Non-linear pullup multi-rate sup sup buses
Non-linear pullup for multi-rate I2C buses
May 13, 2024 Circuits
I2C is a popular bidirectional serial communications bus having a clock and a data line. Both line’s drivers consist of an open drain ground-referenced N-channel MOSFET with a pullup resistor connected to a supply...
Programmable Schmitt triggers are digitally controlled
May 10, 2024 Circuits
The circuit is a single-supply version of a programmable Schmitt trigger, or a comparator with hysteresis...
Seeed unveils compact matter-ready XIAO ESP32C6
Seeed unveils the compact matter-ready XIAO ESP32C6 dev board
Apr 9, 2024 News
Seeed Studio has launched a new entry in the XIAO family of small form factor microcontroller development boards, built around the Espressif ESP32-C6: the RISC-V XIAO ESP32C6, boasting Wi-Fi 6, Bluetooth 5.3 Low Energy (BLE), and Matter-ready IEEE 802.15.4 connectivity...
STMicroelectronics high-performance microcontrollers pave way new
STMicroelectronics' high-performance microcontrollers pave the way to new innovations in smart home and industrial systems
Apr 5, 2024 News
New STM32H7R/S microcontrollers raise embedded-application performance to new levels for next-generation smart devices in factories, buildings, infrastructure, eHealth...
What Is Machine Learning Part Hardware
What Is Machine Learning? Part 3 - Hardware Conversion of Convolutional Neural Networks
Mar 1, 2024 Articles
Part 3 will explain the hardware conversion of a CNN and specifically the benefits of using an artificial intelligence microcontroller with a hardware-based CNN accelerator...
What is machine learning Part Training
What is machine learning? Part 2 - Training convolutional neural networks
Feb 29, 2024 Articles
This is part 2 in a series of articles focusing on the properties and applications of convolutional neural networks, which are mainly used for pattern recognition and the classification of objects...
What is machine learning Part Introduction
What is machine learning? Part 1 - Introduction to convolutional neural networks
Feb 28, 2024 Articles
The world of artificial intelligence (AI) is rapidly evolving, and AI is increasingly enabling applications that were previously unattainable or very difficult to implement. This series of articles explains convolutional neural networks and their significance in machine learning within AI systems...
Control processor power supply real time
Control a processor's power supply in real time
Jan 25, 2024 Circuits
In battery-powered applications in which power management is key, a microprocessor may adjust its core voltage corresponding to an increase or a decrease in clock speed, allowing full processing power when necessary but not wasting excess power when idle...
Use microcontroller design boost converter
Use a microcontroller to design a boost converter
Nov 15, 2023 Articles
Boost converters, like other switchers, have traditionally received their control signals from a dedicated circuit. However, a recent trend is to integrate simple switching-power-supply building blocks into generic devices, such as microcontrollers...
Circuit forms satellite-dish command decoder
Nov 9, 2023 Circuits
By decoding the commands sent by a direct-broadcast satellite receiver that uses the DISEqC protocol, you can troubleshoot the commands or simply listen in...
