Intersil's Dual Synchronous DC/DC Regulator for Automotive Applications
Intersil ISL78228
ISL78228 Delivers Dual 800mA Outputs, Switches at 2.25MHz for High Density
Intersil has announced a space-saving, AEC-Q100-qualified dual synchronous step-down DC/DC regulator featuring a 2.25MHz switching frequency to minimize solution size.
 Intersil - ISL78228
The ISL78228 dual step-down DC/DC regulator provides two independent 800mA outputs. Its 3mm x 3mm package and 2.25MHz switching frequency enables very small power solutions for a variety of space-constrained automotive and industrial applications. A 2.75V to 5.5V input voltage range permits powering from common 3.3V or 5V automotive module supply rails. Internal current-mode compensation provides fast transient response, allowing 100% duty cycle for low dropout and eliminates the need for external compensation components.
Each channel has an independent enable pin and output voltage programming down to 0.6V. Built-in 2ms digital soft-start minimizes inrush current, while the device's low 30uA quiescent current minimizes standby power consumption.
The ISL78228 is AEC-Q100 qualified and fully TS16949 compliant, and is specified for the full -40 degrees C to 105 degrees C operating temperature range.
Features and Specifications
  • Dual 800mA outputs with independent controls
  • 2.75V to 5.5V input voltage range
  • Typical 95% Efficiency (5Vin, 3.3Vout at 250mA)
  • 2.25MHz switching frequency
  • Internal compensation miinimizes external components
  • Internal 2ms digital soft-start and Power Good flag
  • Overcurrent protection and thermal shutdown
  • AEC-Q100 qualified and TS16949 compliant
Pricing and Availability
The ISL78228 is available in a 3mm x 3mm 10-pin exposed pad DFN package with a maximum height of just 0.9mm. Pricing is $0.53 each in 50,000-unit quantities.
intersil.com
