New Family of Devices Offers Industry’s Lowest On-Resistance at 4.5 V
Vishay Intertechnology introduced the first devices in its next-generation TrenchFET® Gen IV family of 30 V n-channel power MOSFETs. Utilizing a new high-density design, the SiRA00DP, SiRA02DP, SiRA04DP, and SiSA04DN offer industry-low on-resistance down to 1.35 mΩ at 4.5 V and low Miller charge, Qgd, down to 1.8 nC in the PowerPAK SO-8 and 1212-8 packages.
The new Vishay Siliconix TrenchFET IV power MOSFETs incorporate technological improvements in silicon design, wafer processing, and device packaging to deliver a number of benefits to designers of today’s power electronics systems. With a reduction in on-resistance times silicon area of over 60 % compared to previous-generation devices, the SiRA00DP is able to demonstrate extremely low RDS(ON) values of 1.0 mΩ at 10 V and an industry-best 1.35 mΩ at 4.5 V. For designers, the MOSFETs’ low on-resistance translates into lower conduction losses for reduced power consumption and higher efficiency.
TrenchFET Gen IV MOSFETs offer a new structure that utilizes a very high-density design without significantly increasing the gate charge, overcoming a problem often associated with high cell count devices. The MOSFETs released today offer low total gate charge and therefore low on-resistance times gate charge figures of merit (FOM) down to 56 nC-Ω at 4.5 V for the SiRA04DP.
The SiRA00DP, SiRA02DP, and SiRA04DP provide increased system efficiency and lower temperatures in the 6.15 mm by 5.15 mm PowerPAK SO-8 package, while the SiSA04DN offers similar efficiency with a third of the size in the 3.30 mm by 3.30 mm PowerPAK 1212-8 package. All of the devices released today offer a very low QGD/QGS ratio of 0.5 or less. This lower ratio can help to prevent shoot-thru by lowering gate induced voltages.
PowerPAK SO-8 vs SO-8 | PowerPAK 1212-8 |
The SiRA00DP, SiRA02DP, SiRA04DP, and SiSA04DN are optimized for high power density DC/DC converters, synchronous rectification, synchronous buck converters, and OR-ing applications. Typical end products include switch mode power supplies, voltage regulator modules (VRMs), POLs, telecom bricks, PCs, and servers.
The TrenchFET Gen IV devices are 100 % RG and UIS tested. They are halogen-free according to the IEC 61249-2-21 definition and RoHS-compliant.
Device Specification Table:
Part #
SiRA00DP
SiRA02DP
SiRA04DP
SiSA04DN
VDS (V)
30
30
30
30
VGS (V)
20
20
20
20
RDS(ON)
(Ω) max. |
VGS = 10 V
0.00100
0.00200
0.00215
0.00215
VGS = 4.5 V
0.00135
0.00270
0.00310
0.00310
QG (nC)
VGS = 4.5 V
66.0
34.3
22.5
22.5
QGS (nC)
26.0
13.6
8.6
8.6
QDS (nC)
8.6
4.1
4.0
4.0
Package
PowerPAK SO-8
PowerPAK 1212-8
Samples of the TrenchFET Gen IV MOSFETs are available now. Production quantities will be available in Q1 2012 with lead times of 12 weeks for large orders.
