Reversible DC Motor Driver from Diodes Incorporated Defeats Space Constraints
Diodes ZXMB5210
Diodes Incorporated introduced a single-chip IC for driving single-coil reversible DC fans and motors. A highly integrated device, in a choice of SO8 and thermally enhanced SO8 exposed pad packages, the ZXBM5210 reduces component count and circuit footprints in medium voltage, low-power applications in consumer, domestic appliance, industrial and office equipment.
Diodes - ZXBM5210
The driver’s integrated high-performance H-bridge output stage can deliver currents as high as 700 mA continuous, 1.2 A peak and has been designed to meet stringent low noise requirements by minimizing both audible switching noise and electromagnetic interference. Its generous supply range of 3 V to 18 V means the device will support a wide variety of single phase 5 V, 9 V, 12 V and 15 V DC motors. Typical operating current is a low 0.85mA.
Achieving highly linear speed control, the ZXBM5210 has four modes of operation: forward, reverse, brake and standby, which are selected via the device’s FWD and REV input pins. Motor speed is regulated by modifying the duty ratio of PWM signals applied to the two inputs or by adjusting the DC input voltage to the VREF input pin. The PWM oscillator is integrated within the device and no external timing capacitor is required.
The ZXBM5210’s standby mode consumes a typical current of only 32 μA, thus improving motor driving power efficiency. To prevent damage to either the motor coil or driver IC, the ZXMB5210 incorporates under-voltage lockout, overvoltage, over-current and thermal shutdown protection functions. Product reliability and robustness is further enhanced by the devices’ high ESD withstand capability of 6kV and wide operating temperature range of -40 ºC to +105 ºC.
diodes.com
