Available with voltage ratings up to 3 Kv and resistance values from 100k up to 100 GOhms, the new Ohmite HVC Series of wrap around terminal chip resistors have a standard TCR of 100ppm and standard tolerances of 5%, although tolerances as low as 0.50% can be achieved. Voltage coefficients range from as low as 10 and up to 100 depending on resistance value.
Supplied in 0805, 1206, and 2512 package sizes, the range comprises 23 stock part numbers. Launched in response to high voltage resistor demands driven by renewable energy, military and medical electronics, the HVC is suitable for vacuum applications as they do not contain any organic compounds.
The thick film resistors have an operating temperature range of –55 °C to +155 °C and the matte tin contact with a nickel barrier is designed for extended shelf life so the product is suitable for inventory support. Parts are delivered in convenient 500 piece reels. Pricing ranges from $0.60-$0.90 in values up 100 meg at 5% tolerance.
