Diodes Incorporated Prolongs Battery Life in Low-Voltage Portable Devices with Low-Power Single Comparator
Diodes AZV3001 AZV3002
Diodes Incorporated introduced the AZV3001. This new generation single-channel comparator has been specifically developed for use in battery-powered equipment that needs to operate at low voltage. The single-channel consumes only 6 μA and provides guaranteed operation from 1.6 V up to 5.5 V, making it well-suited for use in systems with nominal supplies of 1.8 V, 3.0 V or 5.0 V, such as mobile phones, tablets and notebook computers, where it delivers superior performance and helps extend battery life.
Diodes - AZV3001, AZV3002
The comparator features internal hysteresis in order to provide immunity to undesirable small voltage fluctuations, and uses a complementary output stage, comprising P- and N-channel MOSFETS, in order to drive outputs with a full rail-to-rail voltage swing. Miniaturized package options help reduce PCB board space: the AZV3001 is offered in a 6-pin X2-DFN1410-6 package and the dual-channel AZV3002, available later this year, in an 8-pin U-FLGA1616-8 package.
With a low propagation delay of 0.8 μs, a low input bias current of 1 pA and no risk of phase inversion when the input is overdriven, these comparators offer embedded system design engineers a general-purpose solution to almost all low-voltage portable device requirements.
