The IRF3805S-7P (160A continuous) and IRF1405ZS-7P (120A continuous) are designed for heavy-duty, high-current automotive applications such as electronic power steering (EPS), 14V integrated starter alternator (ISA) systems and advanced alternator active rectification.
A standard three-lead D2Pak is limited to 75A to 100A, depending on lead cross-section and manufacturer's specification method; however, International Rectifier's new devices have seven leads. The additional leads allow a larger wirebond area, reducing die-free package resistance, enabling a device on-resistance specification of 2.6mOhm max at 25єC (IRF3805S-7P).
The IRF2804S-7P and the IRF1405ZS-7P are ideal replacements for multiple D2Pak devices as well as larger through-hole package devices. In addition, repetitive avalanche (Ear) is characterized on the data sheet and guaranteed up to maximum junction temperature (Tj-max), especially useful for automotive applications.
Q101-Qualified 55V Automotive HEXFET® MOSFETs | |||||||
Part Number | Package | VDS | RDS(on) | ID, max | Rth | Typ RDS(on) Temp Coeff. | Gate |
IRF3805S-7P | D2Pak-7 | 55V | 2.6 mOhm | 160A(1) | 0.50°C/W | 2.10 | Std |
IRF1405ZS-7P | D2Pak-7 | 55V | 4.9 mOhm | 120A | 0.65°C/W | 2.10 | Std |
Note 1: Package limited |
Availability and Pricing
The new 55V, 7-pin automotive MOSFETs are available immediately. Pricing begins at US $2.85 each for the IRF3805S-7P in 10,000-unit quantities.
