The DS4106, DS4212, and DS4425 ceramic surface-mount crystal oscillators are part of Maxim's DS4-XO series crystal oscillators family. These devices offer output frequencies at 106.25 MHz, 212.5 MHz, and 425 MHz. The clock oscillators are suited for systems with tight tolerances because of the jitter, phase noise, and stability performance. The small package provides a format made for applications where PCB space is critical.
These clock oscillators are crystal based and use a fundamental crystal with PLL technology to provide the final output frequencies. Each device is offered with LVDS or LVPECL output types. The output enable pin is active-high logic.
These clock oscillators have very low phase jitter and phase noise. Typical phase jitter is < 0.9 psRMS from 12 kHz to 20 MHz. The devices are designed to operate with a 3.3 V ±5% supply voltage, and are available in a 5.0 mm x 3.2 mm x 1.49 mm, 10-pin LCCC surface-mount ceramic package.
- Clock Output Frequencies:
- DS4106: 106.25 MHz
- DS4212: 212.50 MHz
- DS4425: 425.00 MHz
- Phase Jitter (RMS): 0.9ps Typical
- LVPECL or LVDS Output
- Supply Current:
- 50 mA (Typical, Unloaded) at +3.3 V Supply (LVPECL)
- 53 mA (Typical) at +3.3V Supply (LVDS)
- -40°C to +85°C Temperature Range
- Output Disable
Category: Timekeeping, Timers, and Counters
