Freescale Introduces MPXV7000 Series Pressure Sensors
Freescale MPXV7002 MPXV7007 MPXV7025
The MPXV7002, MPXV7007 and MPXV7025 are three new integrated pressure sensors designed to measure over pressure and under pressure for supporting a wide range of consumer, appliance, healthcare and industrial applications. Freescale's 7000 series pressure sensors have pressure ranges from 2 kPa to 25 kPa.
Freescale MPXV7000 Series Pressure Sensors
Of particular interest to the designer, these pressure sensors will adjust to the requirements of your application. This capability is perfect for ensuring that your application has positive and negative pressure readings where needed. Benefits include a cost effective way of measuring pressure with real-time feedback and adjustment. The various port options include vertical, single side and dual side ports to accommodate a perfect fit with your application.
