High-Side Power Switches for USB Ports from Diodes Incorporated Cover Power Delivery and Fast Role Swap
Diodes AP22815 AP22615
Diodes Incorporated introduced the AP22815 and AP22615 3 A single-channel high-side power switches for USB ports and other hot-swap applications. These devices are designed to provide protection for any sensitive electronic equipment that is used in a hot-swap situation, such as USB peripherals, portable electronics, or external storage devices.
Diodes - AP22815, AP22615
The highly integrated high-side switches provide extensive port protection with autorecovery, including over-voltage, over-current, short-circuit, and over-temperature. In addition, they feature controlled rise-time and under-voltage lock-out, as well as a discharge function for external storage capacitors.
Based on an N-channel MOSFET and Diodes Incorporated’s patented copper-pillar packaging technology to achieve an exceptionally low on-resistance, the power switches feature a wide input voltage range of 3.0 V to 5.0 V and an adjustable limited load current of up to 4.0 A (AP22615 only). With a low RDS(ON) of just 40 mΩ and high ESD protection (2 kV human body model, 200 V machine model), the AP22815/615 are integrated load switches that are well-suited for a range of applications, including notebooks, netbooks, tablets, set-top boxes, USB chargers, and other consumer electronics.
As well as having integrated load-current limiting, which is adjustable in the AP22615, the high-side power switches are fully compliant with the USB power delivery and fast-role swap specifications. This ensures that the internal power transistor will detect and react to the presence or absence of a power rail within 150 μs, thereby supporting the hot-swapping of USB power sinks and sources without resulting in any disruption to the consumer experience.
Both devices feature an enable-pin (which can be specified to be active-high or active-low) and a dedicated flag output that signals a fault condition. To accommodate devices with high load capacitance, a 7 ms deglitch period is built in to the devices, to avoid false triggers.
