Silicon Germanium (SiGe) rectifiers from Nexperia combine cutting-edge high efficiency, thermal stability and space-savings
Nexperia PMEG120G10ELR PMEG120G20ELP PMEG120G20ELR PMEG120G30ELP
AEC-Q101 approved devices with 120 V, 150 V, and 200 V combine best attributes of Schottky and fast recovery diodes
Nexperia has announced a range of new silicon germanium (SiGe) rectifiers with 120 V, 150 V, and 200 V reverse voltages that combine the high efficiency of their Schottky counterparts with the thermal stability of fast recovery diodes.
Nexperia - PMEG
Targeting automotive, communications infrastructure and server markets, the new 1-3 A SiGe rectifiers are of particular benefit in high-temperature applications like LED lighting, engine control units or fuel injection. Design engineers using the new, extremely low leakage devices can now rely on an extended safe-operating area with no thermal runaway up to 175 degrees. At the same time, they can optimize their design for higher efficiency which is not feasible using fast recovery diodes commonly used in such high-temperature designs. By boosting a low forward voltage (VF) and low QRR, the SiGe rectifiers have an advantage of 10-20 % lower conduction losses.
The PMEG SiGe devices (PMEGxGxELR/P) are housed in size- and thermally-efficient CFP3 and CFP5 packages that have become the industry standard for power diodes. By featuring a solid copper clip the packages’ thermal resistance is reduced and transfer of heat into the ambient environment is optimized, allowing small and compact PCB designs. Moreover, simple pin-to-pin replacements of Schottky and fast recovery diodes are possible when switching to SiGe technology.
The first four AEC-Q101-qualified 120 V SiGe rectifiers are already in mass production. A further eight 150 V and 200 V devices are sampling now.
Main features
Type number Package name VR [max]
(V)
IF [max]
(A)
IR [max]
(μA)
Size
(mm)
PMEG120G10ELR CFP3 120 1.4 0.03 2.6 × 1.7 × 1
PMEG120G20ELP CFP5 120 2.8 0.03 3.8 × 2.5 × 1
PMEG120G20ELR CFP3 120 2.8 0.03 2.6 × 1.7 × 1
PMEG120G30ELP CFP5 120 4.2 0.03 3.8 × 2.5 × 1
