Maxim's Fully integrated, high-voltage scan drivers minimize panel cost in LCD HDTVs
Maxim MAX17120 MAX17121
Maxim's latest scan drivers integrate all logic needed for high-performance scan-driver systems.
Maxim Integrated Products introduces the MAX17120/MAX17121, triple/dual, high-voltage, level-shifting scan drivers for TFT panels with integrated gate logic. These devices minimize panel cost in LCD TVs by integrating all logic required to implement a high-performance scan-driver system. Each scan driver has two channels that switch complementarily. Their outputs swing from +40V to -30V and can swiftly drive capacitive loads. In order to save power, these complementary outputs share the charge of their capacitive load before they change states. These devices are well suited for driving large- (MAX17120) and regular-sized (MAX17121) HDTV LCD panels.
Maxim: MAX17120, MAX17121
The MAX17120 is available in a 5mm x 5mm, 32-pin TQFN package, and the MAX17121 is available in a 4mm x 4mm, 24-pin TQFN; both packages have a maximum thickness of 0.8mm for ultra-thin LCD panels. Prices start at $0.70 (1000-up, FOB USA).
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6200 products serving the industrial, communications, consumer, and computing markets.
Maxim reported revenue in excess of $1.6 billion for fiscal 2009. A Fortune 1000 company, Maxim is included in the Nasdaq 100, the Russell 1000, and the MSCI USA indices.
