Texas Instruments has announced the high-precision temperature sensor TMP114 with an I2C-compatible digital output in an ultra-thin (0.15 mm) 4-pin package. With a low height package, the TMP114 can be put under surface mount components for the fastest and most accurate temperature measurement and supports the latest thin form factor systems.
The TMP114 has an accuracy of ±0.3 °C and offers an on-chip 16-bit analog-to-digital converter (ADC) that provides a temperature resolution of 0.0078 °C.
The TMP114 is designed to operate from a supply voltage range of 1.08 V to 1.98 V, with a low average supply current of less than 0.7 μA. The low supply support, along with extremely low power consumption, is designed for battery-powered applications. The TMP114 is 100% tested on a production setup that is NIST traceable.
Features
- High Accuracy
- ±0.3 °C maximum from –10 °C to +85 °C
- ±0.5 °C maximum from –40 °C to +125 °C
- ±0.1 °C typical
- Operating Temperature Range: –40 °C to +125 °C
- 16-bit Resolution: 0.0078 °C (LSB)
- Low Power Consumption:
- 0.7-μA Average Supply Current
- 0.16-μA Shutdown Current
- Supply Range of 1.08 V to 1.98 V
- 1.2-V Compatible Logic Inputs Regardless of Supply
- I2C and SMBus Compatible Interface
- Optional Cyclic Redundancy Check (CRC) Checksum
- NIST Traceability
- Ultra-Thin 4-Ball PicoStar (DSBGA) Package
Applications
- Mobile phones
- Solid state drives (SSDs)
- Wearable fitness & activity monitors
- Portable electronics
- Set-top boxes (STBs)
- Connected peripherals & printers
The TMP114EVM Evaluation Board. |
