Atmel Analog Companion Chip Enables ARM9-based High-quality Audio and Multimedia Applications
Atmel AT73C246
Atmel Corporation announced production availability of the Atmel AT73C246 analog companion chip to provide power supplies and audio input/output to match the Atmel AT91SAM9 ARM9-based MCUs (and equivalent 32-bit devices) to host multimedia applications. Operating from a single 2.9V to 5.5V source, the AT73C246, when combined with a high-quality stereo audio codec, provides the multi-level supplies required by the AT91SAM9 devices. This combination reduces the external component count and helps keep system power supply to a minimum.
Atmel: AT73C246
Today’s multimedia applications are based on an ARM9 32-bit microcontroller with fast power-hungry devices such as external high-capacity memories and signal processing ICs. Therefore, for both wired and portable devices, system power efficiency is a key factor to decrease power dissipation and to increase battery life. High efficiency and high output current power supplies are also required to meet these requirements.
The AT73C246 integrates two high-efficiency power supply channels designed to supply the core section and the I/O pad section of an ARM9 32-bit MCU-based application. It incorporates an integrated automatic voltage scaling function that allows the application developer to optimize the power efficiency of the system in all operating modes.
In addition, a key feature of many multimedia devices is wireless connectivity to create an Internet-enabled system. The radio frequency section requires a high quality, low-noise power supply to maximize transmission/reception quality. The AT73C246 integrates three low-noise Low Drop Out (LDO) regulators featuring ultra fast transient responses particularly adapted to supply RF ICs.
The most important feature of a multimedia device is its audio/video processing capability. The AT73C246 integrates a complete state-of-the-art low-power stereo audio codec with a headphone amplifier. The input section consists of two selectable stereo inputs (Line/Aux), based on a differential or single-ended mode, to drive a 96dB dynamic range stereo audio ADC through an input mixer. On the output side, a 100dB dynamic range stereo audio DAC drives a 60 mW stereo headphone amplifier through an output mixer. The audio output can also be connected, via an external amplifier, to hi-fi quality speakers. This configuration offers numerous possibilities for mixing audio/voice channels in input/output stages.
Atmel AT73C246
“The AT73C246 is an optimal integration of power supplies and audio interface tailored for multimedia products and specifically for ARM9 32-bit based applications,” said Michele Casetta, marketing manager for power management and audio analog companion (PMAAC) product line, Atmel Corporation. “Usually the market offers power management and analog interface in a single chip for a few high volume applications, such as smartphones or PDAs, where the feature set of the power section supply is larger than the audio section. The AT73C246 feature set is unique because Atmel has reduced the minimum number of power supply cells, while augmenting the features of the audio section, increasing the number of input/output channels and improving the audio quality. This option enables designers to also target small multimedia devices such as music players, picture viewers, etc.”
“Customers have huge advantages choosing an Atmel solution for their application because the AT73C246 is qualified to work with our market-leading family of ARM9-based devices such as the SAM9G10, SAM9G20, SAM9G45, CAP9S, etc. To help with system integration, Atmel also offers application schematics and software drivers,” concluded Michele Casetta.
The AT73C246-EK1 is designed to give designers a quick start to evaluate the power supplies and audio capability of the AT73C246 and for prototyping and testing of new designs. The board is designed to allow an easy evaluation of the products using demonstration software. To increase its capabilities for demonstration, this standalone board has two serial interfaces.
atmel.com
