Product Brochure - Probes and Accessories for Rohde & Schwarz Oscilloscopes (Rohde&Schwarz) - 2
Manufacturer
Rohde&Schwarz
Test applications for oscilloscopes range from debugging complex electronic circuits to measuring the signal integrity of high-speed bus signals and characterizing power electronics with dangerous voltage levels.
Probes and Rohde & Schwarz passive probes are the perfect acces- sory for general measurement applications involving low- accessories for frequency signals. The very fine, spring-loaded tip allows precise and reliable contacting of signal lines. Rohde & Schwarz Active broadband probes are ideal for applications where low loading on the DUT is crucial or when the mea- sured signal contains high-frequency signal components. oscilloscopes Rohde & Schwarz broadband probes feature a very low load and a wide dynamic range. The integrated, high- precision DC voltmeter permits fast and easy testing (both At a glance differential and single-ended) of DC voltage levels on sig- nal lines, irrespective of the oscilloscope settings. The con- figurable, integrated micro button makes it easy to operate the oscilloscope when measuring with multiple probes. An extensive range of probe accessories ensures optimal Test applications for oscilloscopes range from contacting. debugging complex electronic circuits to measuring the signal integrity of high-speed bus signals and Operator safety is the highest priority during measure- characterizing power electronics with dangerous ments on power electronics. Rohde & Schwarz offers high- voltage probes and current probes for measurements up voltage levels. Measurement accuracy and operator to CAT III. safety depend on the probes and accessories that are used. EMC near-field probes open a new application field for oscilloscopes. High sensitivity and the powerful spectrum analysis function make the R&S®RTO oscilloscopes a valu- able tool for analyzing EMC problems when used in con- junction with near-field probes. Key facts ❙ Probes for every application: differential or single- ended voltage measurements, current measurements, EMC near-field measurements ❙ Active probes with very low load due to high input impedance of up to 1 MΩ || 0.3 pF and wide dynamic range of ±8 V ❙ Modular broadband probes with low capacitive loading and flexible and configurable connectivity ❙ R&S®ProbeMeter: integrated voltmeter with 0.1 % measurement uncertainty for precise DC measurements ❙ Simple operation using the configurable micro button ❙ Comprehensive accessories for maximum flexibility during contacting ❙ Passive probes included with every Rohde & Schwarz oscilloscope 2 Probes_and_accessories_bro_en_3606-8866-12_v1301.indd 2 16.07.2018 16:25:43
