RIGOL Probes and Accessories Supported by DS1000Z SeriesRIGOL Passive ProbesRIGOL Active & Current Probes Model Number Type Description Model Number Type Description BW: DC to 300 kHz 1X: DC to 35 MHz Max. input High Z 10X: DC to 150 MHz Current DC: ±100 A, Probe Compatibility: all RIGOL Probe AC P-P: 200 A, scopes. AC RMS: 70 A Compatibility: all RIGOL scopes. PVP2150 RP1001C BW: DC to 1 MHz Max. input 1X: DC to 35 MHz Current DC: ±70 A, High Z 10X: DC to 350 MHz Probe AC P-P: 140 A, Probe Compatibility: AC RMS: 50 A all RIGOL scopes. RP1002C Compatibility: all RIGOL scopes. PVP2350 BW: DC to 50 MHz Max. input Current AC P-P: 50 A (Noncontinuous), DC to 500 MHz Probe AC RMS: 30 A High Z Compatibility: all RIGOL scopes. Probe Compatibility: Must order RP1000P power all RIGOL scopes. RP1003C supply. RP3500A BW: DC to 100 MHz Max. input Current AC P-P: 50 A (Noncontinuous), DC to 300 MHz Probe AC RMS: 30 A Compatibility: all RIGOL scopes. High CAT I 2000 V (DC+AC), Must order RP1000P power Voltage CAT II 1500 V (DC+AC) RP1004C supply. Probe Compatibility: all RIGOL scopes. BW: DC to 10 MHz Max. input AC P-P: 300 A (Noncontinuous), RP1300H Current 500 A (@pulse width ≤30 us), Probe AC RMS: 150 A Compatibility: all RIGOL scopes. DC to 40 MHz Must order RP1000P power DC: 0 to 10 kV DC, RP1005C supply. High Voltage AC: pulse ≤20 kVp-p, Probe AC: sine wave ≤7 kVrms Compatibility: all RIGOL Power Power supply for RP1003C, scopes. Supply RP1004C and RP1005C, support RP1010H 4 channels. RP1000P DC to 150 MHz High DC+AC Peak: 18 kV CAT II High Voltage AC RMS: 12 kV CAT II Voltage BW: 25 MHz Probe Compatibility: all RIGOL Differential Max. Voltage ≤1400 Vpp scopes. Probe Compatibility: all RIGOL scopes. RP1025D RP1018H High BW: 50 MHz Logic Logic analysis probe Voltage Max. Voltage ≤7000 Vpp Analysis (for mixed signal digital Differential Compatibility: all RIGOL scopes. Probe oscilloscope) Probe RP1050D RPL1116 High Voltage BW: 100 MHz Max. Voltage ≤7000 Vpp 50 Ω impedance Differential Adapter Compatibility: all RIGOL scopes. adapter (2 W, 1 GHz) Probe RP1100D RT50J RIGOL 4
