Datasheet AD706 (Analog Devices) - 5
DescriptionDual Picoampere Input Current Bipolar Op Amp
Pages / Page13 / 5 — AD706–Typical Performance Characteristics. (Default Conditions:. 5 V, CL …
RevisionG
File Format / SizePDF / 251 Kb
AD706–Typical Performance Characteristics. (Default Conditions:. 5 V, CL = 5 pF, G = 2, Rg = Rf = 1 k. , RL = 2 k
AD706–Typical Performance Characteristics (Default Conditions: 5 V, CL = 5 pF, G = 2, Rg = Rf = 1 k , RL = 2 k
, RL = 2 k
, VO = 2 V p-p, Frequency = 1 MHz, TA = 25 C) 1000 1000 1000 SAMPLE SAMPLE SAMPLE SIZE: 2400 SIZE: 3000 SIZE: 5100 800 800 800 600 600 600 400 400 400 NUMBER OF UNITS NUMBER OF UNITS NUMBER OF UNITS 200 200 200 0 0 0 –80 –40 0 40 80 –160 –80 0 80 160 –120 –60 0 60 120 INPUT OFFSET VOLTAGE – V INPUT BIAS CURRENT – pA INPUT OFFSET CURRENT – pA
TPC 1. Typical Distribution TPC 2. Typical Distribution TPC 3. Typical Distribution of Input Offset Voltage of Input Bias Current of Input Offset Current
VS 35 100 –0.5 30 C SOURCE RESISTANCE –1.0 V/ MAY BE EITHER BALANCED 25 OR UNBALANCED 10 –1.5 20 FOR INDUSTRIAL TEMPERATURE 15 RANGE 1.5 1.0 10 1.0 (REFERRED TO SUPPLY VOLTAGES) 0.5 OUTPUT VOLTAGE – Volts p-p 5 INPUT COMMON-MODE VOLTAGE LIMIT – Volts OFFSET VOLTAGE DRIFT – –VS 0 0.1 0 5 10 15 20 1k 10k 100k 1M 1k 10k 100k 1M 10M 100M SUPPLY VOLTAGE – Volts FREQUENCY – Hz SOURCE RESISTANCE –
TPC 4. Input Common-Mode Voltage TPC 5. Large Signal Frequency TPC 6. Offset Voltage Drift Range vs. Supply Voltage Response vs. Source Resistance
200 4 60 SAMPLE SIZE: 375 V –55 C TO 125 C 40 160 3 20 POSITIVE IB 120 2 0 80 –20 NUMBER OF UNITS 1 40 NEGATIVE I INPUT BIAS CURRENT – pA B –40 CHANGE IN OFFSET VOLTAGE – 0 0 –60 –0.8 –0.4 0 0.4 0.8 0 1 2 3 4 5 –15 –10 –5 0 5 10 15 OFFSET VOLTAGE DRIFT – V/ C WARM-UP TIME – Minutes COMMON-MODE VOLTAGE – Volts
TPC 7. Typical Distribution TPC 8. Change in Input Offset TPC 9. Input Bias Current vs. of Offset Voltage Drift Voltage vs. Warm-Up Time Common-Mode Voltage –4– REV. E Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM PRODUCT HIGHLIGHTS GENERAL DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALIZATION PHOTOGRAPH Typical Performance Characteristics 1 Hz, 4-Pole, Active Filter OUTLINE DIMENSIONS Revision History
