Datasheet AD706 (Analog Devices) - 4
DescriptionDual Picoampere Input Current Bipolar Op Amp
Pages / Page13 / 4 — AD706. SPECIFICATIONS (continued). AD706J/A. Parameter. Conditions. Min. …
RevisionG
File Format / SizePDF / 251 Kb
AD706. SPECIFICATIONS (continued). AD706J/A. Parameter. Conditions. Min. Typ. Max. Unit. ORDERING GUIDE. ABSOLUTE MAXIMUM RATINGS1
AD706 SPECIFICATIONS (continued) AD706J/A Parameter Conditions Min Typ Max Unit ORDERING GUIDE ABSOLUTE MAXIMUM RATINGS1
POWER SUPPLY Rated Performance ± 15 V Operating Range ±2.0 ±18 V Quiescent Current, Total 0.75 1.2 mA TMIN to TMAX 0.8 1.4 mA TRANSISTOR COUNT Number of Transistors 90 NOTES 1Bias current specifications are guaranteed maximum at either input. 2Input bias current match is the difference between corresponding inputs (I B of –IN of Amplifier 1 minus IB of –IN of Amplifier 2). ∆V ∆V OS1 OS2 CMRR match is the difference between ∆ for Amplifier 1 and for Amplifier 2, expressed in dB. V ∆V CM CM ∆V ∆V OS1 OS2 PSRR match is the difference between ∆ for Amplifier 1 and for Amplifier 2, expressed in dB. V ∆V SUPPLY SUPPLY All min and max specifications are guaranteed. Specifications subject to change without notice.
ORDERING GUIDE ABSOLUTE MAXIMUM RATINGS1 Temperature Package
Supply Voltage . ± 18 V
Model Range Description Option
Internal Power Dissipation AD706JN 0°C to 70°C Plastic DIP N-8 (Total: Both Amplifiers)2 . 650 mW AD706JR 0°C to 70°C SOIC R-8 Input Voltage . ± VS AD706JR-REEL 0°C to 70°C Tape and Reel R-8 Differential Input Voltage3 . +0.7 V AD706JR-REEL7 0°C to 70°C Tape and Reel R-8 Output Short Circuit Duration . Indefinite AD706AR –40°C to +85°C SOIC R-8 Storage Temperature Range (N, R) . –65°C to +125°C AD706AR-REEL –40°C to +85°C Tape and Reel R-8 Operating Temperature Range AD706AR-REEL7 –40°C to +85°C Tape and Reel R-8 AD706J . 0°C to +70°C AD706ARZ-REEL* –40°C to +85°C Tape and Reel R-8 AD706A . –40°C to +85°C Lead Temperature (Soldering 10 secs) . 300°C *Lead-free part. NOTES
METALIZATION PHOTOGRAPH
1Stresses above those listed under Absolute Maximum Ratings may cause perma- nent damage to the device. This is a stress rating only; functional operation of the Dimensions shown in inches and (mm). device at these or any other conditions above those indicated in the operational Contact factory for latest dimensions. section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2Specification is for device in free air:
OUTPUT A 1
8-Lead Plastic Package: θ
+V
JA = 100°C/W
8 S
8-Lead Small Outline Package: θJA = 155°C/W 3The input pins of this amplifier are protected by back-to-back diodes. If the differential voltage exceeds ± 0.7 V, external series protection resistors should be added to limit the input current to less than 25 mA.
–INPUT A 2 0.118 (3.00) 7 OUTPUT B +INPUT A 3 6 –INPUT B 5 –V 4 S +INPUT B 0.074 (1.88) CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although the AD706 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. REV. E –3– Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM PRODUCT HIGHLIGHTS GENERAL DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALIZATION PHOTOGRAPH Typical Performance Characteristics 1 Hz, 4-Pole, Active Filter OUTLINE DIMENSIONS Revision History
