Datasheet AD706 (Analog Devices) - 3
DescriptionDual Picoampere Input Current Bipolar Op Amp
Pages / Page13 / 3 — AD706–SPECIFICATIONS (@ TA = +25. C, VCM = 0 V and. 15 V dc, unless …
RevisionG
File Format / SizePDF / 251 Kb
AD706–SPECIFICATIONS (@ TA = +25. C, VCM = 0 V and. 15 V dc, unless otherwise noted.). AD706J/A. Parameter. Conditions. Min. Typ. Max
AD706–SPECIFICATIONS (@ TA = +25 C, VCM = 0 V and 15 V dc, unless otherwise noted.) AD706J/A Parameter Conditions Min Typ Max
AD706–SPECIFICATIONS (@ TA = +25 C, VCM = 0 V and 15 V dc, unless otherwise noted.) AD706J/A Parameter Conditions Min Typ Max Unit
INPUT OFFSET VOLTAGE Initial Offset 30 100 µV Offset TMIN to TMAX 40 150 µV vs. Temperature, Average TC 0.2 1.5 µV/°C vs. Supply (PSRR) VS = ± 2 V to ± 18 V 110 132 dB TMIN to TMAX VS = ± 2.5 V to ± 18 V 106 126 dB Long Term Stability 0.3 µV/Month INPUT BIAS CURRENT1 VCM = 0 V 50 200 pA VCM = ± 13.5 V 250 pA vs. Temperature, Average TC 0.3 pA/°C TMIN to TMAX VCM = 0 V 300 pA TMIN to TMAX VCM = ± 13.5 V 400 pA INPUT OFFSET CURRENT VCM = 0 V 30 150 pA VCM = ± 13.5 V 250 pA vs. Temperature, Average TC 0.6 pA/°C TMIN to TMAX VCM = 0 V 80 250 pA TMIN to TMAX VCM = ± 13.5 V 80 350 pA MATCHING CHARACTERISTICS Offset Voltage 150 µV TMIN to TMAX 250 µV Input Bias Current2 300 pA TMIN to TMAX 500 pA Common-Mode Rejection 106 dB TMIN to TMAX 106 dB Power Supply Rejection 106 dB TMIN to TMAX 104 dB Crosstalk (Figure 2a) @ f = 10 Hz RL = 2 kΩ 150 dB FREQUENCY RESPONSE Unity Gain Crossover Frequency 0.8 MHz Slew Rate G = –1 0.15 V/µs TMIN to TMAX 0.15 V/µs INPUT IMPEDANCE Differential 40||2 MΩ||pF Common Mode 300||2 GΩ||pF INPUT VOLTAGE RANGE Common-Mode Voltage ±13.5 ± 14 V Common-Mode Rejection Ratio VCM = ± 13.5 V 110 132 dB TMIN to TMAX 108 128 dB INPUT CURRENT NOISE 0.1 Hz to 10 Hz 3 pA p-p f = 10 Hz 50 fA/√Hz INPUT VOLTAGE NOISE 0.1 Hz to 10 Hz 0.5 µV p-p f = 10 Hz 17 nV/√Hz f = 1 kHz 15 22 nV/√Hz OPEN-LOOP GAIN VO = ± 12 V RLOAD = 10 kΩ 200 2000 V/mV TMIN to TMAX 150 1500 V/mV VO = ± 10 V RLOAD = 2 kΩ 200 1000 V/mV TMIN to TMAX 150 1000 V/mV OUTPUT CHARACTERISTICS Voltage Swing RLOAD = 10 kΩ ±13 ± 14 V TMIN to TMAX ±13 ± 14 V Current Short Circuit ± 15 mA Capacitive Load Drive Capability Gain = +1 10,000 pF –2– REV. E Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM PRODUCT HIGHLIGHTS GENERAL DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALIZATION PHOTOGRAPH Typical Performance Characteristics 1 Hz, 4-Pole, Active Filter OUTLINE DIMENSIONS Revision History
