Datasheet LTC1407, LTC1407A (Analog Devices) - 2
DescriptionSerial 12-Bit/14-Bit, 3Msps Simultaneous Sampling ADCs with Shutdown
Pages / Page24 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2). ORDER …
File Format / SizePDF / 408 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Notes 1, 2) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC1407/LTC1407A
Supply Voltage (VDD) ...4V TOP VIEW Analog Input Voltage (Note 3) ... –0.3V to (V CH0+ 1 10 CONV DD + 0.3V) CH0– 2 9 SCK Digital Input Voltage .. –0.3V to (VDD + 0.3V) V 3 REF 11 8 SDO CH1+ 4 7 V Digital Output Voltage ... –0.3V to (V DD DD + 0.3V) CH1– 5 6 GND Power Dissipation ...100mW MSE PACKAGE Operation Temperature Range 10-LEAD PLASTIC MSOP TJMAX = 150°C, θJA = 40°C/W LTC1407C/LTC1407AC ... 0°C to 70°C EXPOSED PAD (PIN #) IS GND, MUST BE SOLDERED TO PCB LTC1407I/LTC1407AI ...– 40°C to 85°C LTC1407H/LTC1407AH ...– 40°C to 125°C Storage Temperature Range ...–65°C to 150°C Lead Temperature (Soldering, 10 sec) .. 300°C
LTC1407CMSE#PBF LTC1407CMSE#TRPBF LTBDQ 10-Lead Plastic MSOP 0°C to 70°C LTC1407IMSE#PBF LTC1407IMSE#TRPBF LTBDR 10-Lead Plastic MSOP –40°C to 85°C LTC1407HMSE#PBF LTC1407HMSE#TRPBF LTBDR 10-Lead Plastic MSOP –40°C to 125°C LTC1407ACMSE#PBF LTC1407ACMSE#TRPBF LTAFE 10-Lead Plastic MSOP 0°C to 70°C LTC1407AIMSE#PBF LTC1407AIMSE#TRPBF LTAFF 10-Lead Plastic MSOP –40°C to 85°C LTC1407AHMSE#PBF LTC1407AHMSE#TRPBF LTAFF 10-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
CONVERTER CHARACTERISTICS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. With internal reference, VDD = 3V. LTC1407 LTC1407A LTC1407H LTC1407AH PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
Resolution (No Missing Codes) l 12 14 12 14 Bits Integral Linearity Error (Notes 5, 17) l –2 ±0.25 2 –4 ±0.5 4 –2 ±0.25 2 –4 ±0.5 4 LSB Offset Error (Notes 4, 17) l –10 ±1 10 –20 ±2 20 –20 ±1 20 –30 ±2 30 LSB Offset Match from CH0 to CH1 (Note 17) –5 ±0.5 5 –10 ±1 10 –5 ±0.5 5 –10 ±1 10 LSB Gain Error (Notes 4, 17) l –30 ±5 30 –60 ±10 60 –40 ±5 40 –80 ±10 80 LSB Gain Match from CH0 to CH1 (Note 17) –5 ±1 5 –10 ±2 10 –5 ±1 5 –10 ±2 10 LSB Gain Tempco Internal Reference (Note 4) ±15 ±15 ±15 ±15 ppm/°C External Reference ±1 ±1 ±1 ±1 ppm/°C 1407fb 2
