Datasheet LTM9002 (Analog Devices) - 3
Description14-Bit, 125Msps Dual-Channel IF/Baseband Receiver Subsystem
Pages / Page28 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 355 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTM9002
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Unless otherwise noted. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
GDIFF Gain DC, LTM9002-AA l 25 26 27 dB fIN = 140MHz 25 dB Channel A, DC (LTM9002-LA) l 19.4 20 20.6 dB fIN = 15MHz 19 dB Channel B, DC (LTM9002-LA) l 7.5 8 8.5 dB fIN = 15MHz 7 dB GTEMP Gain Temperature Drift VIN = MAX, (Note 3) 1.5 mdB/°C Gain Matching External Reference 5 mdB VIN Input Voltage Range for –1dBFS Both Channels, fIN = 140MHz (LTM9002-AA) 100 mVP-P Channel A, fIN = 15MHz (LTM9002-LA) 200 mVP-P Channel B, fIN = 15MHz (LTM9002-LA) 800 mVP-P VINCM Input Common Mode Voltage Range 1 1.5 V RINDIFF Differential Input Impedance Both Channels (LTM9002-AA) 50 Ω Channel A (LTM9002-LA) 200 Ω Channel B (LTM9002-LA) 400 Ω CINDIFF Differential Input Capacitance Includes Parasitic 1 pF VOS Offset Error (Note 5) Including Amplifi er and ADC l –5 0.3 5 mV Offset Matching 0.3 mV Offset Drift Including Amplifi er and ADC ±10 μV/°C CMRR Common Mode Rejection Ratio 50 dB ISENSE SENSE Input Leakage 0V < SENSE < 1V l –3 3 μA IMODE MODE Input Leakage 0V < MODE < VDD l –3 3 μA tAP Sample and Hold Acquisition Delay Time 0 ns tJITTER Sample-and-Hold Acquisition Delay Time Jitter 0.2 psRMS
CONVERTER CHARACTERISTICS The
indicates specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS ADC Characteristics
Resolution (No Missing Codes) LTM9002-AA l 14 Bits LTM9002-LA l 12 Bits INL Integral Linearity Error (Note 4) LTM9002-AA ±1.5 LSB LTM9002-LA ±0.3 LSB DNL Differential Linearity Error LTM9002-AA l –1 ±0.6 1 LSB LTM9002-LA l –1 ±0.2 1 LSB 9002f 3
