Datasheet LTM9002 (Analog Devices) - 4
Description14-Bit, 125Msps Dual-Channel IF/Baseband Receiver Subsystem
Pages / Page28 / 4 — DYNAMIC ACCURACY. The. indicates specifi cations which apply over the full …
File Format / SizePDF / 355 Kb
DYNAMIC ACCURACY. The. indicates specifi cations which apply over the full operating temperature range,
DYNAMIC ACCURACY The indicates specifi cations which apply over the full operating temperature range,
LTM9002
indicates specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Input = –1dBFS. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 70MHz Input (Both Channels), LTM9002-AA 66 dBFS 140MHz Input (Both Channels), LTM9002-AA l 61.5 66 dBFS 15MHz Input (Channel A), LTM9002-LA l 67.7 69.9 dBFS 15MHz Input (Channel B), LTM9002-LA l 68.5 71.1 dBFS SFDR Spurious Free Dynamic Range, 2nd or 3rd 70MHz Input (Both Channels), LTM9002-AA 82 dBc Harmonic 140MHz Input (Both Channels), LTM9002-AA l 67.5 76 dBc 15MHz Input (Channel A), LTM9002-LA l 75 86.2 dBc 15MHz Input (Channel B), LTM9002-LA l 72.7 85.5 dBc SFDR Spurious Free Dynamic Range 4th or Higher 70MHz Input (Both Channels), LTM9002-AA 90 dBc 140MHz Input (Both Channels), LTM9002-AA l 74.2 90 dBc 15MHz Input (Channel A), LTM9002-LA l 78.8 88.5 dBc 15MHz Input (Channel B), LTM9002-LA l 79.8 90.7 dBc S/(N+D) Signal-to-Noise Plus Distortion Ratio 70MHz Input (Both Channels), LTM9002-AA 66 dBFS 140MHz Input (Both Channels), LTM9002-AA l 60.7 66 dBFS 15MHz Input (Channel A), LTM9002-LA l 67.1 69.7 dBFS 15MHz Input (Channel B), LTM9002-LA l 67.9 70.8 dBFS IMD3 Third Order Inter-Modulation Distortion; 70MHz Input, LTM9002-AA 77 dBc 1MHz Tone Spacing, Two Tones –7dBFS 140MHz Input, LTM9002-AA 73 dBc 15MHz Input, LTM9002-LA 77 dBc Crosstalk 140MHz Input, LTM9002-AA –110 dB 15MHz Input, LTM9002-LA –110 dB
AUXILIARY DAC CHARACTERISTICS The
indicates specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Not applicable for LTM9002-LA) (Note 3) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution l 12 Bits Monotonicity l 12 Bits Full-Scale Range Internal Reference 1.5 V Settling Time ±0.024% (±1LSB at 12 Bits), 83.5 μs No External Sense Capacitor
DIGITAL INPUTS AND OUTPUTS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Logic Inputs (CLK, OE, ADCSHDN, MUX, CS/LD, SCK, SDI)
VIH High Level Input Voltage VDD = 3V l 2 V VIL Low Level Input Voltage VDD = 3V l 0.8 V IIN Input Current VIN = 0V to VDD l –10 10 μA CIN Input Capacitance (Note 6) 3 pF 9002f 4
