Datasheet LT1355, LT1356 (Analog Devices) - 3
DescriptionDual and Quad 12MHz, 400V/µs Op Amps
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS. TA = 25°C, VCM = 0V unless otherwise noted. …
File Format / SizePDF / 692 Kb
ELECTRICAL CHARACTERISTICS. TA = 25°C, VCM = 0V unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. VSUPPLY. MIN. TYP. MAX. UNITS
ELECTRICAL CHARACTERISTICS TA = 25°C, VCM = 0V unless otherwise noted SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
LT1355/LT1356
ELECTRICAL CHARACTERISTICS TA = 25°C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage ±15V 0.3 0.8 mV ±5V 0.3 0.8 mV ±2.5V 0.4 1.0 mV IOS Input Offset Current ±2.5V to ±15V 20 70 nA IB Input Bias Current ±2.5V to ±15V 80 300 nA en Input Noise Voltage f = 10kHz ±2.5V to ±15V 10 nV/√Hz in Input Noise Current f = 10kHz ±2.5V to ±15V 0.6 pA/√Hz RIN Input Resistance VCM = ±12V ±15V 70 160 MΩ Input Resistance Differential ±15V 11 MΩ CIN Input Capacitance ±15V 3 pF Input Voltage Range+ ±15V 12.0 13.4 V ±5V 2.5 3.5 V ±2.5V 0.5 1.1 V Input Voltage Range– ±15V –13.2 –12.0 V ±5V –3.4 –2.5 V ±2.5V –0.9 –0.5 V CMRR Common Mode Rejection Ratio VCM = ±12V ±15V 83 97 dB VCM = ±2.5V ±5V 78 84 dB VCM = ±0.5V ±2.5V 68 75 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V 92 106 dB AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 1k ±15V 12 36 V/mV VOUT = ±10V, RL = 500Ω ±15V 5 15 V/mV VOUT = ±2.5V, RL = 1k ±5V 12 36 V/mV VOUT = ±2.5V, RL = 500Ω ±5V 5 15 V/mV VOUT = ±2.5V, RL = 150Ω ±5V 1 4 V/mV VOUT = ±1V, RL = 500Ω ±2.5V 5 20 V/mV VOUT Output Swing RL = 1k, VIN = ±40mV ±15V 13.3 13.8 ±V RL = 500Ω, VIN = ±40mV ±15V 12.0 13.0 ±V RL = 500Ω, VIN = ±40mV ±5V 3.5 4.0 ±V RL = 150Ω, VIN = ±40mV ±5V 2.75 3.3 ±V RL = 500Ω, VIN = ±40mV ±2.5V 1.3 1.7 ±V IOUT Output Current VOUT = ±12.0V ±15V 24.0 30 mA VOUT = ±2.75V ±5V 18.3 25 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±3V ±15V 30 42 mA SR Slew Rate AV = –2 (Note 4) ±15V 200 400 V/µs ±5V 70 120 V/µs Full-Power Bandwidth 10V Peak (Note 5) ±15V 6.4 MHz 3V Peak (Note 5) ±5V 6.4 MHz GBW Gain Bandwidth f = 200kHz, RL = 2k ±15V 9.0 12.0 MHz ±5V 7.5 10.5 MHz ±2.5V 9.0 MHz tr, tf Rise Time, Fall Time AV = 1, 10% to 90%, 0.1V ±15V 14 ns ±5V 17 ns Overshoot AV = 1, 0.1V ±15V 20 % ±5V 18 % Propagation Delay 50% VIN to 50% VOUT , 0.1V ±15V 16 ns ±5V 19 ns ts Settling Time 10V Step, 0.1%, AV = –1 ±15V 230 ns 10V Step, 0.01%, AV = –1 ±15V 280 ns 5V Step, 0.1%, AV = –1 ±5V 240 ns 5V Step, 0.01%, AV = –1 ±5V 380 ns 13556fc 3 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Applications Related Parts
