Use an LM317 as 0 to 3V adjustable regulator
Fairchild LM317
Vladimir Rentyuk
EDN
Most engineers know that they can use an inexpensive, three-terminal adjustable regulator, such as Fairchild Semiconductor’s LM317, as an adjustable regulator to only some necessary value of voltage, such as 36 or 3 V. This value cannot be less than 1.25 V without employing other approaches, however. The devices’ inner reference voltage is 1.25 V, and their output voltage accordingly cannot be less than this value without potential bias (Reference 1). One way to solve this problem is to use a reference-voltage source based on two diodes (Reference 2).
Figure 1. This circuit is an inexpensive approach using a simple 0 to 3V adjustable regulator.
Although this approach is suitable for a 1.2 to 15 V or higher-voltage regulator, it is not appropriate for an extra-low-voltage fixed- or adjustable-voltage regulator. The two 1N4001 diodes it employs do not provide the needed potential bias of 1.2V, and they have additional temperature instability of approximately 2.5 mV/K (Reference 3). Hence, additional temperature drifting of the output voltage is approximately 100 mV; it is more than 6% for a 1.5 V output voltage and 10% for a 1 V output voltage if you adjust the temperature to 20 °C – a typical indoor situation.
You can solve these problems by using a Fairchild Semiconductor LM185 or an Analog Devices AD589 adjustable-voltage-reference IC. These devices are expensive, however, and, in this case, they require not only additional zero adjustment but also matching. These adjustments at their reference voltages are 1.215 to 1.255 V and 1.2 to 1.25 V for the LM185 and AD589, respectively. Note that the reference voltage of the LM317 is 1.2 to 1.3 V.
Figure 1 shows an inexpensive approach using a simple 0 to 3V adjustable regulator. You implement the necessary potential bias using a simple temperature-stabilized constant-current source (Reference 4). You calculate this current source using the following equation:
where VF is D1’s forward voltage of approximately 2 V and VEBO is Q1’s emitter-base voltage of approximately 0.68 V. The current is approximately
The constant-current source creates a bias voltage of approximately –1.25 V on resistor R3. You implement the zero adjustment using resistor R6, which can change the current of the constant-current source. Resistor R5 protects transistor Q1. You can use D1 as a light indicator. You can adjust the output voltage using resistor R2. Calculate the output voltage as follows:
where VREF is the reference voltage of IC1 and VR3 is some compensative voltage of resistor R3. You should establish this voltage to equal the reference voltage for its compensation. In this case
With R2 having a value of 1.2 kΩ, this circuit found use as the equivalent of a typical battery with an output voltage of 1.56 V for development projects.
References
  1. “LM317 3-Terminal Positive Adjustable Regulator,” Fairchild Semiconductor Corp, June 2005.
  2. “LM350 3-Terminal 3A Positive Adjustable Voltage Regulator,” Fairchild Semiconductor Corp, 2001.
  3. Schenk, C, and Ulrich Tietze, Halbleiter-Schaltungstechik, Springer-Verlag Berlin Heidelberg, 2002, ISBN: 3540428496.
  4. Rentyuk, Vladimir, “The Simple Temperature-Stabilized Constant-Current Source,” Electronics World, November 2006.
EDN
