Weather Station
Weather station with pressure reading, relative humidity, indoor & remote outdoor temperature display.Both Celsius or Fahrenheit & mbar/hPa or mm Hg supported. With calendar & clock. Easy 3-button user-menu. 42 hour-history display (curve). Auto-memory & display of all high and low-values. PIC 18F452 running at 4 MHz, power saving sleep mode. Sensors are only turned on when needed..
Circuit Explanation:
Now this was a huge project! All sensors had to be fully tested one at a time, wireless communication had to be perfect, various LCDs were tried. Nevertheless, here's the result: hope you enjoy it!
The circuit may be powered by a small 9V battery, but you'd better take a couple of AA-batteries. A 6-pack will last a several months. Consumption for the base station is around 8 to 9 mA whilst active and only 2 to 3 mA in sleep mode (LCD remains on.) The transmitter takes slightly less.
The receiver (base station) is active during 5 seconds & then goes to sleep for 45 seconds. The transmitter takes a nap every 30 seconds or so.
Menu mode is entered when pushing the "menu" button (what's in a name?) for 1 second. Browsing & value changes are done with the "min" & "plus" keys. When in normal mode (like in the picture above), the "min" and "plus" keys can browse through the different histories. All these controls will wake up the processor if it was in sleep mode.
On the left-hand side of the LCD we have (from top to bottom :) Outside temperature, Pressure, inside Temperature, Relative Humidity, Calendar and Clock.
On the right: High value of the past 42-hours, Bar graph histogram (right is most recent value), Low value.
All sensors are read & LCD (left-hand side) are updated every 50 seconds. Histogram is updated on the hour (e.g. 10h00, 17h00, 22h00,...). All data is stored in EEPROM and is loaded at power-up. In case of a power failure (or when changing batteries), there will be no data (nor history) lost.
MPX 4115A pressure sensor Most expensive part of the project (around € 20,- / $ 25,-), but it's worth it. Output of this sensor is an analogue voltage, which is temperature-compensated! We'll feed this directly to the PIC's 10-bit ADC.
TC77 SPI temperature sensor Nice SPI-sensor in a tiny SO-08 package. We'll use an emulated SPI-mode since we're already using I²C for the RTC (with a DS1307) and the external memory (24LC256), but this works just as well. Resolution goes to one tenth of a degree Celsius!
H1 humidity sensor This sensor's output is a capacitance between 112pF (at 10% RH) and 143pF (90% RH) Its curve is not linear so we'll use a simple table to convert the A/D reading to the correct RH-value. Capacitance to frequency conversion is done with a simple 555 timing circuit. This frequency is fed to the PIC's T1_CLK.
RX+TX433: wireless modules These are cheap modules. They have a quite good range (to 25m indoors and 150m outdoors.) Data size of one packet is 32 bits. Bits 8 (LSB) to 19 (MSB) contain temperature data (BCD). Bit 21 is the minus sign, bit 23 is a low battery warning.
Schematics: right-click & "save picture as" for full resolution or (recommended) download the eagle-file below.
Click for enlarge
Base-station (receiver)
Click for enlarge
Transmitter
Remote temperature sensor (transmitter) compatible with HUGER & OREGON SCIENTIFIC remote sensors
Parts Lists (Bill of material):
Receiver, Calibration:
Pressure calibration
Make sure you're using a reliable multimeter, and not a cheap one. First adjust VREF- (PIC RA2, pin 4) to 2V40 with trimmer R9. Then adjust VREF+ (RA3, pin 5) to 4V70 with trimmer R8. At last, do a manual (linear) pressure correction via the menu (see below.) Of course, you'll have to know the current pressure for your area ... but this is just once!
Humidity calibration:
Temperature calibration:
No need, the TC77 sensors are fully calibrated.
Downloads:
WARNING: may not be duplicated for any commercial use whatsoever without explicit consent from the author (c) Michel Bavin
For the base-station (receiver:)
For the remote temperature sensor (transmitter:)
PCB ScreenshotsBase station (receiver:)
Remote transmitter (outside temperature:)
www.elxproject.com/elx/news.php?readmore=36
