Lead Acid Battery Charger #2
Izhar Fareed
The above pictured schematic diagram is just a standard constant current model with a added current limiter, consisting of Q1, R1, and R4. The moment too much current is flowing biases Q1 and drops the output voltage.
The output voltage is: 1.2 × (P1+R2+R3)/R3 volt. Current limiting kicks in when the current is about 0.6/R1 amp.
For a 6-volt battery which requires fast-charging, the charge voltage is 3 × 2.45 = 7.35 V. (3 cells at 2.45v per cell). So the total value for R2 + P1 is then about 585 ohm. For a 12 V battery the value for R2 + P1 is then about 1290 ohm.
For this power supply to work efficiently, the input voltage has to be a minimum of 3V higher than the output voltage.
P1 is a standard trimmer potentiometer of sufficient watt for your application.
The LM317 must be cooled on a sufficient (large) coolrib.
Q1 (BC140) can be replaced with a NTE128 or the older ECG128 (same company).
Except as a charger, this circuit can also be used as a regular power supply.
Parts List
R1
0.56 Ohm, 5W, WW
R2
470 Ohm
R3
120 Ohm
R4
100 Ohm
C1
1000uF/63V
C2
220nF
Q1
BC140
Q2
LM317, Adj. Volt Reg.
C3
220nF (On large coolrib!)
P1
220 Ohm
electronics-lab.com
