Datasheet AD8613, AD8617, AD8619 (Analog Devices) - 6
DescriptionLow Cost Micropower, Low Noise CMOS Rail-to-Rail, Input/Output Operational Amplifiers
Pages / Page16 / 6 — AD8613/AD8617/AD8619. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. …
RevisionH
File Format / SizePDF / 291 Kb
AD8613/AD8617/AD8619. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1800. 400. VSY = 5.5V. –0.5V < V. VSY = 5V AND 1.8V. 1600
AD8613/AD8617/AD8619 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 1800 400 VSY = 5.5V –0.5V < V VSY = 5V AND 1.8V 1600
VSY = 5 V or ±2.5 V, unless otherwise noted.
1800 400 VSY = 5.5V –0.5V < V VSY = 5V AND 1.8V 1600 CM < +5.5V TA = 25°C 350 1400 S 300 R IE 1200 IF L NT (pA) 250 P M 1000 A F CURRE 200 O 800 R E B 150 M 600 T BIAS U U N 100 400 INP 200
03
50
0 2- 62
0
05
0
05622-006
0 25 50 75 100 125 150 1100 –800 –500 –200 100 400 700 1000 1300 1600 1900 –200 –1700 –1400 TEMPERATURE (°C) INPUT OFFSET VOLTAGE (µV)
Figure 5. Input Offset Voltage Distribution Figure 8. Input Bias Current vs. Temperature
40 50 –40°C < TA < 125°C T V A = 25°C CM = 2.5V 35 40 S 30 R ) A IE µ IF ( 25 T PL 30 M EN A R R F 20 U O C ER 20 15 LY P MB P U N SU 10 10
4
5
07 00 -0 2- 22
0
562 0
0
056
0 1 2 3 4 5 6 7 8 9 10 0 1 2 3 5 TCVOS (µV/°C) SUPPLY VOLTAGE (V)
Figure 6. Input Offset Voltage Drift Distribution Figure 9. Supply Current vs. Supply Voltage
2000 V 50 SY = 5V V T SY = ±2.5V, ±1.35V, ±0.9V A = 25°C 1500 V)
A) 40 µ 1000 R ( E ( E G FI A T 500 LI L 30 AMP VO 0 ET NT/ S F F –500 20 O T CURRE Y PU –1000 L IN P UP 10 –1500 S
05 -0 22
–2000
056
0
05622-008
–0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 –40 –10 20 50 80 110 INPUT COMMON MODE VOLTAGE (V) TEMPERATURE (°C)
Figure 7. Input Offset Voltage vs. Input Common-Mode Voltage Figure 10. Supply Current vs. Temperature Rev. H | Page 6 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
