Datasheet AD8029, AD8030, AD8040 (Analog Devices) - 4
DescriptionLow Power, High Speed Rail-to-Rail Input/Output Amplifier
Pages / Page24 / 4 — AD8029/AD8030/AD8040. Data Sheet. Parameter. Conditions. Min. Typ. Max. …
File Format / SizePDF / 454 Kb
AD8029/AD8030/AD8040. Data Sheet. Parameter. Conditions. Min. Typ. Max. Unit. SPECIFICATIONS WITH +5 V SUPPLY
AD8029/AD8030/AD8040 Data Sheet Parameter Conditions Min Typ Max Unit SPECIFICATIONS WITH +5 V SUPPLY
link to page 5
Short-Circuit Current Sinking and Sourcing 170/160 mA Off Isolation (AD8029) VIN = 0.1 V p-p, f = 1 MHz, DISABLE = Low –55 dB Capacitive Load Drive 30% Overshoot 20 pF POWER SUPPLY Operating Range 2.7 12 V Quiescent Current/Amplifier 1.4 1.5 mA AD8040W only: TMIN to TMAX 1.85 mA Quiescent Current (Disabled) DISABLE = Low, AD8029 only 150 200 µA Power Supply Rejection Ratio Vs ± 1 V 73 80 dB AD8040W only: TMIN to TMAX 72 dB 1 Plus, +, (or no sign) indicates current into pin; minus (–) indicates current out of pin.
SPECIFICATIONS WITH +5 V SUPPLY Table 2. VS = 5 V @ TA = 25°C, G = +1, RL = 1 kΩ to midsupply, unless otherwise noted. All specifications are per amplifier. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Bandwidth G = +1, VO = 0.1 V p-p 80 120 MHz AD8040W only: TMIN to TMAX 80 MHz G = +1, VO = 2 V p-p 13 18 MHz AD8040W only: TMIN to TMAX 8 MHz Bandwidth for 0.1 dB Flatness G = +2, VO = 0.1 V p-p 6 MHz Slew Rate G = +1, VO = 2 V Step 55 V/µs G = –1, VO = 2 V Step 60 V/µs Settling Time to 0.1% G = +2, VO = 2 V Step 82 ns NOISE/DISTORTION PERFORMANCE Spurious Free Dynamic Range (SFDR) fC = 1 MHz, VO = 2 V p-p –73 dBc fC = 5 MHz, VO = 2 V p-p –55 dBc Input Voltage Noise f = 100 kHz 16.5 nV/√Hz Input Current Noise f = 100 kHz 1.1 pA/√Hz Crosstalk (AD8030/AD8040) f = 5 MHz, VIN = 2 V p-p –79 dB DC PERFORMANCE Input Offset Voltage PNP Active, VCM = 2.5 V 1.4 5 mV AD8040W only: TMIN to TMAX 8.5 mV NPN Active, VCM = 4.5 V 1.8 6 mV AD8040W only: TMIN to TMAX 8.5 mV Input Offset Voltage Drift TMIN to TMAX 25 µV/°C Input Bias Current1 NPN Active, VCM = 4.5 V 0.8 1.2 µA TMIN to TMAX 1 µA PNP Active, VCM = 2.5 V –1.8 –2.8 µA TMIN to TMAX 2 µA Input Offset Current ±0.1 ±0.9 µA AD8040W only: TMIN to TMAX ±0.9 µA Open-Loop Gain Vo = 1 V to 4 V 65 74 dB AD8040W only: TMIN to TMAX 62 dB INPUT CHARACTERISTICS Input Resistance 6 MΩ Input Capacitance 2 pF Input Common-Mode Voltage Range –0.2 to +5.2 V Common-Mode Rejection Ratio VCM = 0.25 V to 2 V, RL = 10 kΩ 80 90 dB AD8040W only: TMIN to TMAX 80 dB DISABLE PIN (AD8029) DISABLE Low Voltage –VS + 0.8 V DISABLE Low Current –6.5 µA DISABLE High Voltage –VS + 1.2 V Rev. B | Page 4 of 24 Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications Specifications with ±5 V Supply Specifications with +5 V Supply Specifications with +3 V Supply Absolute Maximum Ratings Maximum Power Dissipation Output Short Circuit ESD Caution Typical Performance Characteristics Theory of Operation Input Stage Output Stage Applications Wideband Operation Output Loading Sensitivity Disable Pin Circuit Considerations PCB Layout Grounding Power Supply Bypassing Design Tools and Technical Support Outline Dimensions Ordering Guide
