Datasheet OP292, OP492 (Analog Devices) - 7
DescriptionDual/Quad Single-Supply Operational Amplifiers
Pages / Page20 / 7 — Data Sheet. OP292/OP492. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 160. …
RevisionD
File Format / SizePDF / 345 Kb
Data Sheet. OP292/OP492. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 160. VS = 5V. 175. VCM = 0V. 140. S = 5V. A = 25°C. CM = 0V. 720 OP AMPS
Data Sheet OP292/OP492 TYPICAL PERFORMANCE CHARACTERISTICS 200 160 VS = 5V 175 VCM = 0V 140 S = 5V A = 25°C CM = 0V 720 OP AMPS
Data Sheet OP292/OP492 TYPICAL PERFORMANCE CHARACTERISTICS 200 160 VS = 5V V 175 VCM = 0V 140 S = 5V T V A = 25°C CM = 0V 720 OP AMPS TA = 25°C 150 120 600 OP AMPS 125 100 S T ITS 100 80 N U UNI 75 60 50 40 25 20
003
0
00310-
0 –500 –400 –300 –200 –100 0 100 200 300 400 500 –0.5 –0.4 –0.3 –0.2 –0.1 0 0.1 0.2 0.3 0.4 0.5 0.6
006
INPUT OFFSET VOLTAGE, V INPUT OFFSET VOLTAGE, V OS (µV) OS (mV)
00310- Figure 3. OP292 Input Offset Voltage Distribution @ 5 V Figure 6. OP492 Input Offset Voltage Distribution @ 5 V
320 240 VS = ±15V V V S = ±15V 280 CM = 0V V T CM = 0V A = 25°C 200 T 720 OP AMPS A = 25°C 240 600 OP AMPS 160 200 S ITS 160 T 120 N U UNI 120 80 80 40 40
004
0
00310-
0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0
007
INPUT OFFSET VOLTAGE, VOS (mV) INPUT OFFSET VOLTAGE, VOS (mV)
00310- Figure 4. OP292 Input Offset Voltage Distribution @ ±15 V Figure 7. OP492 Input Offset Voltage Distribution @ ±15 V
160 160 VS = 5V V V S = 5V 140 CM = 0V –40°C ≤ T 140 VCM = 0V A ≤ +125°C –40°C ≤ T 600 OP AMPS A ≤ +125°C 120 120 600 OP AMPS 100 100 S ITS 80 T N 80 U UNI 60 60 40 40 20 20
005
0
00310-
0 0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0
008
TCVOS (µV/°C) TCVOS (µV/°C)
00310- Figure 5. OP292 Temperature Drift (TCVOS) Distribution @ 5 V Figure 8. OP492 Temperature Drift (TCVOS) Distribution @ 5 V Rev. D | Page 7 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION PHASE REVERSAL POWER SUPPLY CONSIDERATIONS TYPICAL APPLICATIONS DIRECT ACCESS ARRANGEMENT FOR TELEPHONE LINE INTERFACE SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER DAC OUTPUT AMPLIFIER 50 Hz/60 Hz SINGLE-SUPPLY NOTCH FILTER FOUR-POLE BESSEL LOW-PASS FILTER LOW COST, LINEARIZED THERMISTOR AMPLIFIER SINGLE-SUPPLY ULTRASONIC CLAMPING/LIMITING RECEIVER AMPLIFIER PRECISION SINGLE-SUPPLY VOLTAGE COMPARATOR PROGRAMMABLE PRECISION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
