Datasheet LTC2209 (Analog Devices) - 8
Description16-Bit, 160Msps ADC
Pages / Page32 / 8 — tiMing DiagraMs. Full-Rate CMOS Output Mode Timing. All Outputs are …
File Format / SizePDF / 612 Kb
tiMing DiagraMs. Full-Rate CMOS Output Mode Timing. All Outputs are Single-Ended and Have CMOS Levels
tiMing DiagraMs Full-Rate CMOS Output Mode Timing All Outputs are Single-Ended and Have CMOS Levels
LTC2209
tAP N + 1 N + 4 ANALOG INPUT N N + 3 N + 2 tH tL ENC– ENC+ tD DA0-DA15, OFA N – 7 N – 6 N – 5 N – 4 N – 3 tC CLKOUTA CLKOUTB DB0-DB15, OFB HIGH IMPEDANCE 2209 TD02
Demultiplexed CMOS Output Mode Timing All Outputs are Single-Ended and Have CMOS Levels
tAP N + 1 N + 4 ANALOG INPUT N N + 3 N + 2 tH tL ENC– ENC+ tD DA0-DA15, OFA N – 8 N – 6 N – 4 tD DB0-DB15, OFB N – 7 N – 5 N – 3 tC CLKOUTA CLKOUTB 2209 TD03 2209fb 8 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Common Mode Bias Characteristics Digital Inputs and Digital Outputs Power Requirements Timing Characteristics Electrical Characteristics Timing Diagram Typical Performance Characteristics Pin Functions Block Diagram Definitions Applications Information Package Description Revision History Related Parts
