Datasheet HMCAD1511 (Analog Devices) - 7
DescriptionHigh Speed Multi-Mode 8-Bit 1 GSPS A/D Converter
Pages / Page31 / 7 — HMCAD1511. HigH Speed Multi-Mode 8-Bit. 30 MSpS to 1 gSpS A/d Converter. …
HMCAD1511. HigH Speed Multi-Mode 8-Bit. 30 MSpS to 1 gSpS A/d Converter. pin Configuration and description
HMCAD1511 HigH Speed Multi-Mode 8-Bit 30 MSpS to 1 gSpS A/d Converter pin Configuration and description
HMCAD1511
v04.1015
0 t M s s - r e t Figure 2: Package diagram r e
table 3: pin descriptions
v
Pin Name Description Pin Number # Of Pins
n AvDD Analog power supply, 1.8v 1, 36 2 o Csn Chip select enable. Active low 2 1 sDAtA serial data input 3 1 sCLK serial clock input 4 1 resetn reset sPI interface. Active low 5 1 Power-down input. Activate after applying power in order to initialize the ADC correctly. PD 6 1 A / D C Alternatively use the sPI power down feature DvDD Digital and I/o power supply, 1.8v 7, 30 2 Dvss Digital ground 8, 29 2 DP1A LvDs channel 1A, positive output 9 1 Dn1A LvDs channel 1A, negative output 10 1 DP1B LvDs channel 1B, positive output 11 1 Dn1B LvDs channel 1B, negative output 12 1 DP2A LvDs channel 2A, positive output 13 1 Dn2A LvDs channel 2A, negative output 14 1 DP2B LvDs channel 2B, positive output 15 1 Dn2B LvDs channel 2B, negative output 16 1 LCLKP LvDs bit clock, positive output 17 1 LCLKn LvDs bit clock, negative output 18 1 Informatio For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, n furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringement MA 02062-9106 s of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise Phone: 781-329-4700 • Order online at www.analog.com under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com
0 - 6
Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Application Support: Phone: 1-800-ANALOG-D
