Datasheet AD9430 (Analog Devices) - 9
Description12-Bit, 170/210 MSPS 3.3 V A/D Converter
Pages / Page45 / 9 — AD9430. SWITCHING SPECIFICATIONS. Table 4. Test. AD9430-170. AD9430-210. …
RevisionE
AD9430. SWITCHING SPECIFICATIONS. Table 4. Test. AD9430-170. AD9430-210. Parameter (Conditions). Temp. Level. Min. Typ. Max. Unit
AD9430 SWITCHING SPECIFICATIONS Table 4 Test AD9430-170 AD9430-210 Parameter (Conditions) Temp Level Min Typ Max Unit
link to page 45 link to page 9 link to page 9 link to page 9 link to page 45 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9
AVDD = 3.3 V, DRVDD = 3.3 V, TMIN = –40°C, TMAX = +85°C, unless otherwise noted.
Table 4. Test AD9430-170 AD9430-210 Parameter (Conditions) Temp Level Min Typ Max Min Typ Max Unit
Maximum Conversion Rate1 Full VI 170 210 MSPS Minimum Conversion Rate1 Full V 40 40 MSPS CLK+ Pulse Width High (tEH)1 Full IV 2 12.5 2 12.5 ns CLK+ Pulse Width Low (tEL)1 Full IV 2 12.5 2 12.5 ns DS Input Setup Time (tSDS)2 Full IV –0.5 –0.5 ns DS Input Hold Time (tHDS)2 Full IV 1.75 1.75 ns OUTPUT (CMOS Mode) Valid Time (tV) Full IV 2 2 ns Propagation Delay (tPD) Full IV 3.8 5 3.8 5 ns Rise Time (tR) (20% to 80%) 25°C V 1 1 ns Fall Time (tF) (20% to 80%) 25°C V 1 1 ns DCO Propagation Delay (tCPD) Full IV 3.8 5 3.8 5 ns Data to DCO Skew (tPD to tCPD) Full IV –0.5 0 +0.5 –0.5 0 +0.5 ns Interleaved Mode (A, B Latency) Full IV 14, 14 14, 14 Cycles Parallel Mode (A, B Latency) Full IV 15, 14 15, 14 Cycles OUTPUT (LVDS Mode) Valid Time (tV) Full VI 2.0 2.0 ns Propagation Delay (tPD) Full VI 3.2 4.3 3.2 4.3 ns Rise Time (tR) (20% to 80%) 25°C V 0.5 0.5 ns Fall Time (tF) (20% to 80%) 25°C V 0.5 0.5 ns DCO Propagation Delay (tCPD) Full VI 1.8 2.7 3.8 1.8 2.7 3.8 ns Data to DCO Skew (tPD – tCPD) Full IV 0.2 0.5 0.8 0.2 0.5 0.8 ns Latency Full IV 14 14 Cycles APERTURE DELAY (tA) 25°C V 1.2 1.2 ns APERTURE UNCERTAINTY (Jitter, tJ) 25°C V 0.25 0.25 ps rms OUT OF RANGE RECOVERY TIME (CMOS and LVDS) 25°C V 1 1 Cycles 1 All ac specifications tested by differentially driving CLK+ and CLK−. 2 DS inputs used in CMOS mode only. Rev. E | Page 8 of 44 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION APPLICATIONS TABLE OF CONTENTS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY APPLICATION NOTES THEORY OF OPERATION ENCODE INPUT ANALOG INPUT DS INPUTS (DS+, DS–) CMOS OUTPUTS LVDS OUTPUTS VOLTAGE REFERENCE NOISE POWER RATIO TESTING (NPR) EVALUATION BOARD, CMOS MODE POWER CONNECTOR ANALOG INPUTS GAIN ENCODE VOLTAGE REFERENCE DATA FORMAT SELECT I/P TIMING SELECT TIMING CONTROLS CMOS DATA OUTPUTS CRYSTAL OSCILLATOR OPTIONAL AMPLIFIER TROUBLESHOOTING EVALUATION BOARD, LVDS MODE POWER CONNECTOR ANALOG INPUTS GAIN CLOCK VOLTAGE REFERENCE DATA FORMAT SELECT DATA OUTPUTS CRYSTAL OSCILLATOR OUTLINE DIMENSIONS ORDERING GUIDE
