Datasheet ADL5562 (Analog Devices) - 8
Description3.3 GHz Ultralow Distortion RF/IF Differential Amplifier
Pages / Page21 / 8 — ADL5562. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. MAXIMUM GAIN. …
RevisionF
File Format / SizePDF / 566 Kb
ADL5562. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. MAXIMUM GAIN. –40°C +25°C. +85°C. MID GAIN. Bm). N (. B (. MAX GAIN –40°C
ADL5562 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS MAXIMUM GAIN –40°C +25°C +85°C MID GAIN Bm) N ( B ( MAX GAIN –40°C
VCC = 3.3 V, VCOM = 1.65 V, RL = 200 Ω differential, AV = 6 dB, CL = 1 pF differential, f = 140 MHz, T = 25°C.
16 15 MAXIMUM GAIN –40°C +25°C 14 +85°C 13 14 12 11 12 MID GAIN 10 9 B) Bm) d d 8 10 N ( B ( AI 7 1d G P 6 O MAX GAIN –40°C 8 5 MAX GAIN +25°C MAX GAIN +85°C 4 MID GAIN –40°C 3 MID GAIN +25°C 6 MINIMUM GAIN MID GAIN +85°C 2 MIN GAIN –40°C 1 MIN GAIN +25°C MIN GAIN +85°C 4 0 10M 100M 1G 10G
002
0 50 100 150 200 250
017
FREQUENCY (Hz) FREQUENCY (MHz)
08003- 08003- Figure 3. Gain vs. Frequency Response for 200 Ω Differential Load, Figure 6. Output P1dB (OP1dB) vs. Frequency at AV = 6 dB, AV = 12 dB, and AV = 6 dB, AV = 12 dB, and AV = 15.5 dB over Temperature AV = 15.5 dB over Temperature, 200 Ω Differential Load
20 14 –40°C +25°C 18 +85°C 12 16 MAXIMUM GAIN 10 14 B) Bm) 8 d d MID GAIN 12 N ( B ( AI 1d G P 6 10 O MAX GAIN –40°C MAX GAIN +25°C 4 MAX GAIN +85°C 8 MID GAIN –40°C MID GAIN +25°C MINIMUM GAIN MID GAIN +85°C 6 2 MIN GAIN –40°C MIN GAIN +25°C MIN GAIN +85°C 4 0 10M 100M 1G 10G
003
016
08003- 08003- Figure 4. Gain vs. Frequency Response for 1 kΩ Differential Load, Figure 7. Output P1dB (OP1dB) vs. Frequency at AV = 6 dB, AV = 12 dB, and AV = 6 dB, AV = 12 dB, and AV = 15.5 dB over Temperature AV = 15.5 dB over Temperature, 1 kΩ Differential Load
16 8 AV MAXIMUM AV MAXIMUM AV MID AV MID 14 AV MINIMUM ) 7 AV MINIMUM √Hz 12 V/ 6 ) (n Y dB IT ( 10 5 E NS R 8 DE 4 L FIGU A E R T 6 3 OIS N 4 2 ISE SPEC O N 2 1 0 0 10 100 1000
004
10M 100M 1G
005
FREQUENCY (MHz) FREQUENCY (Hz)
08003- 08003- Figure 5. Noise Figure vs. Frequency at Figure 8. Noise Spectral Density vs. Frequency AV = 6 dB, AV = 12 dB, and AV = 15.5 dB at AV = 6 dB, AV = 12 dB, and AV = 15.5 dB Rev. F | Page 8 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
