Datasheet ADL5562 (Analog Devices) - 9
Description3.3 GHz Ultralow Distortion RF/IF Differential Amplifier
Pages / Page21 / 9 — Data Sheet. ADL5562. –40. AV MAXIMUM. AV MID. AV MINIMUM. –60. –20. Bc). …
RevisionF
File Format / SizePDF / 566 Kb
Data Sheet. ADL5562. –40. AV MAXIMUM. AV MID. AV MINIMUM. –60. –20. Bc). –80. Ω (. Bm) d. 200 –100. 3 (. D3, –120. D3,. –140. –100. –160. –120. 100. 150. 200. 250
Data Sheet ADL5562 –40 AV MAXIMUM AV MID AV MINIMUM –60 –20 Bc) –80 Ω ( Bm) d 200 –100 3 ( D3, –120 D3, –140 –100 –160 –120 100 150 200 250
Data Sheet ADL5562 60 –40 0 AV MAXIMUM AV MAXIMUM 55 AV MID AV MID AV MINIMUM AV MINIMUM –60 –20 50 45 Bc) –80 –40 Bc) d d 40 Ω ( Ω ( Bm) d 1k 35 200 –100 –60 3 ( = = L L IP R O 30 R D3, –120 –80 D3, 25 IM IM 20 –140 –100 15 10 –160 –120
020
0 50 100 150 200 250
018
0 50 100 150 200 250 FREQUENCY (MHz) FREQUENCY (MHz)
08003- 08003- Figure 9. Output Third-Order Intercept at Three Gains, Output Level at 2 V p-p Figure 12. Two-Tone Output IMD vs. Frequency, Output Level Composite, RL = 200 Ω at 2 V p-p Composite, RL = 200 Ω and RL = 1 kΩ
60 50 +85°C +25°C –40°C 45 50 40 35 40 30 Bm) d Bm) 30 d 3 ( 25 3 ( IP O IP O 20 20 15 10 10 5 0 0 0 50 100 150 200 250
019
–2 –1 0 1 2 3 4 5
028
FREQUENCY (MHz)
08003-
POUT/TONE (dBm)
08003- Figure 10. Output Third-Order Intercept vs. Frequency, Over Temperature, Figure 13. Output Third-Order Intercept (OIP3) vs. Power (POUT), Output Level at 2 V p-p Composite, RL = 200 Ω Frequency 140 MHz, AV = 15.5 dB
60 –70 AV MAXIMUM AV MAXIMUM AV MID AV MID A –75 V MINIMUM AV MINIMUM 55 –80 50 –85 Bm) Bc) d d 45 –90 3 ( D ( IP IM O –95 40 –100 35 –105 30 –110 0 50 100 150 200 250 0 50 100 150 200 250
007 006
08003- 08003- Figure 11. OIP3 vs. Frequency (Single-Ended Input) Figure 14. IMD vs. Frequency (Single-Ended Input) Rev. F | Page 9 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
