Datasheet LTC5507 (Analog Devices)
Description100kHz to 1GHz RF Power Detector
Pages / Page8 / 1 — FEATURES. DESCRIPTIO. Temperature Compensated Internal Schottky. Diode RF …
File Format / SizePDF / 134 Kb
FEATURES. DESCRIPTIO. Temperature Compensated Internal Schottky. Diode RF Detector. Wide Input Power Range: –34dBm to 14dBm
Datasheet LTC5507 Analog Devices
LTC5507 100kHz to 1GHz RF Power Detector
U FEATURES DESCRIPTIO
The LTC®5507 is an RF power detector for applications
Diode RF Detector
operating from 100kHz to 1000MHz. The input frequency ■
range is determined by an external capacitor. A tempera- ■
Ultra Wide Input Frequency Range: 100kHz to
ture-compensated Schottky diode peak detector and buffer
1000MHz
amplifier are combined in a small 6-pin ThinSOT package. ■
Buffered Output
The RF input voltage is peak detected using an on-chip ■
Wide VCC Range of 2.7V to 6V
Schottky diode and external capacitor. The detected volt- ■ Low Operating Current: 550µA age is buffered and supplied to the VOUT pin. A power ■ Low Shutdown Current: <2µA saving shutdown mode reduces supply current to less ■ Low Profile (1mm) ThinSOTTM Package than 2µA.
U
, LTC and LT are registered trademarks of Linear Technology Corporation.
APPLICATIO S
ThinSOT is a trademark of Linear Technology Corporation ■ Wireless Transceivers ■ Wireless and Cable Infrastructure ■ RF Power Alarm ■ Envelope Detector
U TYPICAL APPLICATIO Typical Detector Characteristics at 100kHz, 100MHz and 1000MHz
10000 TA = 25°C VCC = 2.7V TO 6V LTC5507 V 4 3 OUT V V CC OUT DETECTED VBAT VOLTAGE 2.7V TO 6V C2 5 2 PCAP GND C1 1000 RF 6 1 RF SHDN 100kHz, 100MHz IN DISABLE ENABLE INPUT 5507 TA01 OUTPUT VOLTAGE (mV) 1000MHz OUTV
Figure 1. 100kHz to 1000MHz RF Power Detector
100 –34 –26 –18 –10 –2 6 14 RF INPUT POWER (dBm) 5507 TA01b 5507f 1
