Datasheet LTC5507 (Analog Devices) - 3
Description | 100kHz to 1GHz RF Power Detector |
Pages / Page | 8 / 3 — TYPICAL PERFOR A CE CHARACTERISTICS. LTC5507 Typical Detector. … |
File Format / Size | PDF / 134 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS. LTC5507 Typical Detector. Characteristics, 100kHz,. Characteristics, 100MHz
LTC5507
W U TYPICAL PERFOR A CE CHARACTERISTICS LTC5507 Typical Detector LTC5507 Typical Detector Characteristics, 100kHz, Characteristics, 100MHz VCC = 2.7V TO 6V VCC = 2.7V TO 6V
10000 10000 C1 = 0.47µF C1 = 1000pF C2 = 0.47µF C2 = 1000pF 1000 1000 OUTPUT VOLTAGE (mV) TA = –40°C OUTPUT VOLTAGE (mV) TA = –40°C TA = 85°C OUT OUT V V TA = 85°C TA = 25°C TA = 25°C 100 100 –34 –28 –22 –16 –10 –4 2 8 14 –34 –28 –22 –16 –10 –4 2 8 14 RF INPUT POWER (dBm) RF INPUT POWER (dBm) 5507 G01 5507 G02
LTC5507 Typical Detector Characteristics, 1000MHz Positive VOUT Slew Rate vs C2 V Capacitance CC = 2.7V TO 6V
10000 10.0 C1 = 33pF C2 = 33pF µs) 1.0 1000 SLEW RATE (V/ OUT 0.10 OUTPUT VOLTAGE (mV) TA = –40°C TA = 85°C OUTV POSITIVE V TA = 25°C 100 0.01 –34 –28 –22 –16 –10 –4 2 8 14 33 330 3300 33000 330000 RF INPUT POWER (dBm) C2 CAPACITANCE (pF) 5507 G03 5507 G04
Negative VOUT Slew Rate vs C2 Capacitance VOUT BW vs C2 Capacitance
10.000 10000 µs) 1.000 1000 0.100 SLEW RATE (V/ 100 BW (kHz) OUT 0.010 OUTV 10 0.001 NEGATIVE V 0 1 33 330 3300 33000 330000 33 330 3300 33000 330000 C2 CAPACITANCE (pF) C2 CAPACITANCE (pF) 5507 G05 5507 G06 5507f 3
