Datasheet LTC5507 (Analog Devices) - 7
Description100kHz to 1GHz RF Power Detector
Pages / Page8 / 7 — PACKAGE DESCRIPTIO. S6 Package. 6-Lead Plastic TSOT-23
File Format / SizePDF / 134 Kb
PACKAGE DESCRIPTIO S6 Package 6-Lead Plastic TSOT-23
LTC5507
U PACKAGE DESCRIPTIO S6 Package 6-Lead Plastic TSOT-23
(Reference LTC DWG # 05-08-1636) 2.90 BSC 0.62 0.95 (NOTE 4) MAX REF 1.22 REF 1.50 – 1.75 2.80 BSC 3.85 MAX 2.62 REF 1.4 MIN (NOTE 4) PIN ONE ID RECOMMENDED SOLDER PAD LAYOUT 0.30 – 0.45 0.95 BSC PER IPC CALCULATOR 6 PLCS (NOTE 3) 0.80 – 0.90 0.20 BSC 0.01 – 0.10 1.00 MAX DATUM ‘A’ 0.30 – 0.50 REF 0.09 – 0.20 1.90 BSC (NOTE 3) S6 TSOT-23 0302 NOTE: 1. DIMENSIONS ARE IN MILLIMETERS 2. DRAWING NOT TO SCALE 3. DIMENSIONS ARE INCLUSIVE OF PLATING 4. DIMENSIONS ARE EXCLUSIVE OF MOLD FLASH AND METAL BURR 5. MOLD FLASH SHALL NOT EXCEED 0.254mm 6. JEDEC PACKAGE REFERENCE IS MO-193 5507f Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no represen- tation that the interconnection of its circuits as described herein will not infringe on existing patent rights. 7
