Datasheet ADIS16006 (Analog Devices) - 6
DescriptionDual-Axis ±5 g Accelerometer with SPI Interface
Pages / Page17 / 6 — Data Sheet. ADIS16006. CIRCUIT AND TIMING DIAGRAMS. 200µA. IOL. TO …
RevisionC
File Format / SizePDF / 290 Kb
Data Sheet. ADIS16006. CIRCUIT AND TIMING DIAGRAMS. 200µA. IOL. TO OUTPUT. 1.6V. PIN. 50pF. IOH. tACQ. tCONVERT. SCLK. THREE-STATE. DOUT
Data Sheet ADIS16006 CIRCUIT AND TIMING DIAGRAMS 200µA IOL TO OUTPUT 1.6V PIN 50pF IOH tACQ tCONVERT SCLK THREE-STATE DOUT
Data Sheet ADIS16006 CIRCUIT AND TIMING DIAGRAMS 200µA IOL TO OUTPUT 1.6V PIN CL 50pF
2 00
200µA IOH
5- 97 05 Figure 2. Load Circuit for Digital Output Timing Specifications
tACQ tCONVERT CS t1 t6 SCLK 1 2 3 4 5 6 15 16 t2 t7 t t 3 8 THREE-STATE THREE-STATE DOUT 4 LEADING ZEROS DB11 DB10 DB9 DB0 t4 t5
3 -00
DIN DON’T
75
CARE ZERO ZERO ZERO ADD0 ONE ZERO PM0
59 0 Figure 3. Accelerometer Serial Interface Timing Diagram
TCS t1 t6 SCLK 1 2 3 4 11 15 16 THREE- t t 3 7 t8 STATE THREE-STATE DOUT LEADING DB9 DB8 DB0 ZERO
4 -00
DIN
75 59 0 Figure 4. Temperature Serial Interface Timing Diagram Rev. C | Page 5 of 16 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Circuit and Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Data Format Self-Test Serial Interface Accelerometer Serial Interface Accelerometer Control Register Power-Down ADD0 ZERO ONE DONTC Accelerometer Conversion Details Temperature Sensor Serial Interface Read Operation Write Operation Temperature Sensor Control Register ZERO Output Data Format Temperature Sensor Conversion Details Power Supply Decoupling Setting the Bandwidth Selecting Filter Characteristics: The Noise/Bandwidth Trade-Off Applications Second Level Assembly Outline Dimensions Ordering Guide
