ADIS16006Data SheetABSOLUTE MAXIMUM RATINGSTable 3.Table 4. Package CharacteristicsParameterRatingPackage TypeθJAθJCDevice Weight Acceleration (Any Axis, Unpowered) 3500 g 12-Terminal LGA 200°C/W 25°C/W 0.3 grams Acceleration (Any Axis, Powered) 3500 g VCC −0.3 V to +7.0 V 3.18658× All Other Pins (COM − 0.3 V) to (VCC + 0.3 V) 1.797 Output Short-Circuit Duration Indefinite 8× (Any Pin to Common) 0.670 8× Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C 6.3733.5942×4× Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational 0.500 section of this specification is not implied. Exposure to absolute 1.12712×12× maximum rating conditions for extended periods may affect 005 device reliability. 7.2mm × 7.2mm STACKED LGA. ALL DIMENSIONS IN mm. 05975- Figure 5. Second-Level Assembly Pad Layout ESD CAUTION Rev. C | Page 6 of 16 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Circuit and Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Data Format Self-Test Serial Interface Accelerometer Serial Interface Accelerometer Control Register Power-Down ADD0 ZERO ONE DONTC Accelerometer Conversion Details Temperature Sensor Serial Interface Read Operation Write Operation Temperature Sensor Control Register ZERO Output Data Format Temperature Sensor Conversion Details Power Supply Decoupling Setting the Bandwidth Selecting Filter Characteristics: The Noise/Bandwidth Trade-Off Applications Second Level Assembly Outline Dimensions Ordering Guide
