ADIS16003Data SheetABSOLUTE MAXIMUM RATINGSTable 4. Package CharacteristicsTable 3.Package TypeθJAθJC DeviceWeightParameter Rating 12-Terminal LGA 200°C/W 25°C/W 0.3 grams Acceleration (Any Axis, Unpowered) 3500 g Acceleration (Any Axis, Powered) 3500 g 3.1865 VCC −0.3 V to +7.0 V 8× All Other Pins (COM − 0.3 V) to (V 1.797 CC + 0.3 V) 8× Output Short-Circuit Duration 0.670 (Any Pin to Common) Indefinite 8× Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C 6.3733.5942×4× Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any 0.500 other conditions above those indicated in the operational 1.12712× section of this specification is not implied. Exposure to absolute 12× 23 0 3- maximum rating conditions for extended periods may affect 46 7.2mm × 7.2mm STACKED LGA. ALL DIMENSIONS IN mm. 05 device reliability. Figure 5. Second-Level Assembly Pad Layout ESD CAUTION Rev. B | Page 6 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS CIRCUIT AND TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ACCELEROMETER DATA FORMAT SELF-TEST SERIAL INTERFACE ACCELEROMETER SERIAL INTERFACE Accelerometer Control Register Power Down ADD0 ZERO ONE DONTC Accelerometer Conversion Details TEMPERATURE SENSOR SERIAL INTERFACE Read Operation Write Operation Temperature Sensor Control Register ZERO Output Data Format Temperature Sensor Conversion Details POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH SELECTING FILTER CHARACTERISTICS:THE NOISE/BANDWIDTH TRADE-OFF APPLICATIONS INFORMATION DUAL-AXIS TILT SENSOR Converting Acceleration to Tilt SECOND LEVEL ASSEMBLY OUTLINE DIMENSIONS ORDERING GUIDE
