KSZ8775CLX TABLE 2-1: Num Pins SIGNALS (CONTINUED) Pin Name Type Port Pin Description RMII: Port 4 SW4-RMII receive bit [0]. Strap Option: Clock or Normal Mode Select in Port 4 RMII 43 RXD4_0 Ipd/O 4 PU = Clock mode in RMII, using 25MHz OSC clock and provide 50 MHz RMII clock from pin RXC4 (Default) PD = Normal mode in RMII, the TXC4/REFCLKI4 pin on the Port 4 RMII will receive an external 50 MHz clock Note: Port 4 also can use either an internal or external clock in RMII mode based on this strap pin or the setting of the Register 70 (0x46) bit [7]. An external pull-up/down resistor is requested for the strap-in. 44 RXDV4/CRSDV4 IPD/O 45 NC NC 46 VDD12D P 47 TXC5/REFCLKI5/ GTXC5 I/O 4 RMII: CRSDV4 is for Port 4 RMII carrier sense/receive data valid output. No connect 5 1.2V core power 5 Port 5 Switch GMAC5 Clock Pin: MII: 2.5/25 MHz clock, PHY mode is output, MAC mode is input. RMII: Input for receiving 50 MHz in normal mode. RGMII: Input 125 MHz clock with falling and rising edge to latch data for the data transfer. 48 RXC5/ GRXC5 I/O 5 Port 5 Switch GMAC5 Clock Pin: MII: 2.5/25 MHz clock, PHY mode is output, MAC mode is input. RMII: Output 50 MHz reference clock for the receiving/transmit in the clock mode. RGMII: Output 125 MHz clock with falling and rising edge to latch data for the receiving. 49 RXD5_0 IPD/O 5 RGMII/MII/RMII: Port 5 switch receive bit [0] 50 RXD5_1 IPD/O 5 RGMII/MII/RMII: Port 5 switch receive bit [1] 51 GNDD GND 52 VDDIO P 53 RXD5_2 2015 Microchip Technology Inc. IPD/O Digital ground 3.3V, 2.5V, or 1.8V digital VDD for digital I/O circuitry. 5 RGMII/MII: Port 5 switch receive bit [2] RMII: No connection. DS00002129C-page 9
