Datasheet HMC361G8 (Analog Devices) - 2
DescriptionSMT GaAs HBT MMIC DIVIDE-BY-2, 0.01 - 13 GHz
Pages / Page6 / 2 — HMC361G8. SMT GaAs HBT MMIC. DIVIDE-BY-2, 0.01 - 13 GHz. Input …
File Format / SizePDF / 475 Kb
HMC361G8. SMT GaAs HBT MMIC. DIVIDE-BY-2, 0.01 - 13 GHz. Input Sensitivity Window, T= 25 °C
HMC361G8 SMT GaAs HBT MMIC DIVIDE-BY-2, 0.01 - 13 GHz Input Sensitivity Window, T= 25 °C
HMC361G8
v00.1111
SMT GaAs HBT MMIC DIVIDE-BY-2, 0.01 - 13 GHz Input Sensitivity Window, T= 25 °C Input Sensitivity Window vs. Temperature
15 15 10 10 t 5 5 M (dBm) 0 (dBm) 0 Min Pin +25C Max Pin +25C s -5 Min Pin +25C -5 Min Pin +85C Max Pin +25C Max Pin +85C POWER Min Pin -40C POWER -10 -10 Max Pin -40C s - INPUT -15 INPUT -15 r -20 -20 o t -25 -25 0 2 4 6 8 10 12 14 0 2 4 6 8 10 12 14 c INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) e t e
SSB Phase Noise Performance vs. Output Power vs. Temperature Temperature, Pin= 0 dBm, Fin = 6 GHz
6 -110 s & D 4 -120 +25C +85C r -40C e (dBm) 2 (dBc/Hz) -130 iD 0 POWER NOISE iv -140 -2 PHASE OUTPUT + 25C -4 -150 + 85C y D SSB - 40C c -6 -160 n 0 2 4 6 8 10 12 14 102 103 104 105 106 107 108 INPUT FREQUENCY (GHz) e OFFSET FREQUENCY (Hz) u q
Output Harmonic
e
Content, Pin= 0 dBm, T= 25 °C Reverse Leakage, Pin= 0 dBm, T= 25 °C
r 0 0 F -10 -10 Both Output Ports Terminated One Output Port Terminated -20 -20 (dBm) (dBm) -30 -30 LEVEL LEVEL -40 -40 OUTPUT POWER -50 Pin_FEEDTHRU -50 3rd HARMONIC -60 -60 0 2 4 6 8 10 12 14 1 2 3 4 5 6 7 8 9 10 11 12 13 14 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
2
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
