Datasheet HMC361G8 (Analog Devices) - 5
DescriptionSMT GaAs HBT MMIC DIVIDE-BY-2, 0.01 - 13 GHz
Pages / Page6 / 5 — HMC361G8. SMT GaAs HBT MMIC. DIVIDE-BY-2, 0.01 - 13 GHz. Evaluation PCB
File Format / SizePDF / 475 Kb
HMC361G8 SMT GaAs HBT MMIC DIVIDE-BY-2, 0.01 - 13 GHz Evaluation PCB
HMC361G8
v00.1111
t M s s - r o t c e t e s & D r e iD iv y D c n e u q e
List of Materials for Evaluation PCB EVAL01-HMC361G8 [1]
r F The circuit board used in the application should use item Description rF circuit design techniques. signal lines should J1 - J3 connector, sMA, Female have 50 ohm impedance while the package ground J4, J5 Dc Pins leads and backside ground slug should be con- c1 - c4 ATC530L, Broadband Capacitor, 0402 Pkg. nected directly to the ground plane similar to that c5 1000 pF capacitor, 0603 Pkg. shown. A sufficient number of via holes should be c6 10 uF tantalum capacitor, 1206 Pkg. used to connect the top and bottom ground planes. u1 HMc361G8 The evaluation circuit board shown is available PcB [2] 106580 evaluation PcB from Hittite upon request. This evaluation board is [1] Reference this number when ordering complete evaluation PCB designed for single ended input testing. J2 and J3 [2] circuit Board Material: rogers 4350 provide differential output signals. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
