Datasheet HMC361G8 (Analog Devices) - 3
DescriptionSMT GaAs HBT MMIC DIVIDE-BY-2, 0.01 - 13 GHz
Pages / Page6 / 3 — HMC361G8. SMT GaAs HBT MMIC. DIVIDE-BY-2, 0.01 - 13 GHz. Output Voltage …
File Format / SizePDF / 475 Kb
HMC361G8. SMT GaAs HBT MMIC. DIVIDE-BY-2, 0.01 - 13 GHz. Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
HMC361G8 SMT GaAs HBT MMIC DIVIDE-BY-2, 0.01 - 13 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
HMC361G8
v00.1111
SMT GaAs HBT MMIC DIVIDE-BY-2, 0.01 - 13 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C Absolute Maximum Ratings
600 rF input (vcc = +5v) +13 dBm t vcc +5.5v 400 M storage temperature -65 to +150 °c s 200 esD sensitivity (HBM) 100v (mV) 0 s - r -200
Reliability Information
AMPLITUDE o -400 Junction temperature to Maintain t 135 °c 1 Million Hour MttF c -600 nominal Junction temperature e 126 °c 22.7 22.9 23.1 23.3 23.5 23.7 23.9 24.1 24.3 24.5 24.7 (t = 85 °c and Pin = + 10 dBm) t TIME (ns) thermal resistance (rth) 96.9 °c/W e
Typical Supply Current vs. Vcc, T= 25
°c (Junction to GnD Paddle, 5v supply) operating temperature -40 to +85 °c vcc (v) icc (mA) 4.75 76 s & D 5.0 84 r 5.25 90 eLectrostAtic sensitive Device e Note: Divider will operate over full voltage range shown above oBserve HAnDLinG PrecAutions iD iv
Outline Drawing
y D c n e u q e r F notes: 1. PAcKAGe MAteriAL: ALuMinA LoADeD BorosiLicAte GLAss. 2. LeAD, BAse, cover MAteriAL: KovAr™ (#7052 corninG). 3. PLAtinG: eLectroLytic GoLD 50 MicroincHes Min., over eLectroLytic nicKeL 50 MicroincHes Min. 4. DiMensions Are in incHes [MiLLiMeters]. 5. toLerAnces: ±.005 [0.13] unLess otHerWise sPeciFieD. 6. ALL GrounD LeADs AnD GrounD PADDLe Must Be soLDereD to PcB rF GrounD. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
