Datasheet HMC705LP4, HMC705LP4E (Analog Devices) - 5
Description6.5 GHz Programmable Divider (N = 1 - 17)
Pages / Page12 / 5 — HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). Output …
HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). Output Voltage Waveform, Fin = 500 MHz,
HMC705LP4 / HMC705LP4E 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17) Output Voltage Waveform, Fin = 500 MHz,
v04.0212
6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17) Output Voltage Waveform, Fin = 500 MHz, Output Voltage Waveform, Fin = 750 MHz, N = 2, Pin = 0 dBm, T= 25 °C N = 3, Pin = 0 dBm, T= 25 °C
300 400 t 200 300 M s 100 200 (mV) (mV) 0 100 s - r -100 0 AMPLITUDE AMPLITUDE o t -200 -100 c -300 -200 e 25 26 27 28 29 30 31 26 27 28 29 30 31 32 33 t TIME (ns) TIME (ns) e
Output Voltage Waveform, Fin = 2500 MHz, Output Voltage Waveform, Fin = 4250 MHz, N = 10, Pin = 0 dBm, T= 25 °C N = 17, Pin = 0 dBm, T= 25 °C
s & D 200 100 r 100 e 0 0 iD -100 (mV) (mV) -100 iv -200 -200 -300 y D AMPLITUDE -300 AMPLITUDE c -400 -400 n -500 -500 e 32 33 34 35 36 37 38 25 26 27 28 29 30 u TIME (ns) TIME (ns) q e r F n output Duty cycle (%) 1 input 2 50 3 - 17 [ 1 - (2/n) ] x 100 note: [1] Peak to peak amplitude does not change relative to n. [2] Pulse duty cycle changes relative to n. I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
